K12OOLT 2005
My rear brake was locking up. had to rebuild rear caliper.
I have been bleeding the rear brake for 2 hours with my Mity vaccum pump.
The rear reservoir isn't going down on fluid. I put clean fluid in the reservoir.I'm getting dirty fluid when bleeding is that from ABS control unit?
To get any fluid when bleeding the with the vaccum pump, I have to run the bike shut it off and bleed a couple times. Then start the bike do it again.
