Turn Signal switch
I am having some difficulty with my LH turn signal switch. 99 R1100 GS
Bulbs, socket, etc all in good working order. It is the switch. I have taken it apart and can get it to come on intermittently in various positions. Obviously losing contact somewhere. All solder points look good. No wiggle in them at all. Recently detailed the bike. Started after the detailing. No high pressure water was used. Just garden hose strength. Didn't really spend much time at the handlbars anyways. But it is definitely in the switch. Any ideas?
Thanks,
Brian
fixed. Took the switch apart. Let it hang for a day and dry if that was the problem. cleaned the dust and what not and put back together. Works fine now.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
