Dthornburg
For the past year I have reviewed quite a few threads on the BMWMOA Forums talking about problems installing a CB unit on 2005 K1200LT and I couldn't find a solution to my specific problem within the Forum.
I have a 2005 K1200LT that came with a BMW ComSystem installed. The ComSystem was made by the J & M Corporation specifically for the K1200LT and it works fine. I have attached a Word Document showing what my ComSystem looks like and J & M has confirmed that this ComSystem was made by them.
I and a local BMW Dealership have been trying for the past several months to connect up a Midland CB, Model 75-822 with very limited success. After numerous emails with J & M trying to resolve the issue I was finally told that there was only one CB unit that would work with and integrate through the ComSystem I have. J & M said the CB they are referring to is a J & M CB unit made specifically for the BMW K1200LT.
John Lazzeroni, President of J & M emailed a copy of the owner's manual for this CB and it looks like an older model of the JMCB-2003, which mounts on the left handle bar. The part number for this BMW CB radio kit is 99 99 0 006 072. I and a local BMW Dealership can't find any reference to this part number nor what is included in the kit.
The owner's manual John sent has a graphic drawing shows multiple cables/connectors and how they connect together to integrate the CB unit so that it work through the BMW ComSystem. It shows how the connections run to work separate PTT buttons for the Rider and Passenger as well as their helmets, how to connect up GPS unit (I have and it is a BMW Navigator II) and antenna, ground, etc.
Does anyone have any information about part number 99 99 0 006 072 and what it includes?
Do you know where I can find/purchase this specific CB unit?
If CB radio kit doesn't include all the cables/connectors to integrate it with the BMW ComSystem, does anyone have part numbers for the necessary cables/connectors to do so and where can I find them?
There is some light at the end of the tunnel and that is J & M said (John Lazzeroni) that if I can't find this specific unit anywhere, J & M will be do a run of this CB unit toward the end of 2010. I sure would like to have one before then is possible. I will appreciate any help or leads anyone can give at this time.
AZDIRTRIDER
AZDIRTRIDER
