Gerbing Permanent Controller Install DIY
Semper_Fi
Honey Badger
The articles, posts and comments in this tech section are posted by individual members and reflect their personal thoughts and experiences with repairing, maintaining, and generally working on motorcycles. This information may require specific knowledge and skills, may or may not be correct or current to model.
The authors of information found here and the BMW MOA take no responsibility for ensuring the accuracy of any information (including procedures, techniques, parts numbers, torque values, tool usage, etc.), or further for any damage of any kind or injuries incurred or caused by anyone following the instructions or information found here.
It is the duty of the individual to either assume the liability himself for responsibly using the information found here, or to take the bike or accessory to a Dealer or other qualified professional service.
Lastly, please ensure you dispose of your used chemicals, oils and fuels in an environmentally responsible manner. Most Auto Parts stores and service stations will accept used oil and lubricants, tires and batteries, please check for your local availability.
This article, text and photos are Copyright of the individual authors and the BMW MOA, any copying or redistributing is permitted only by prior written authorization.
This DIY covers installing a Gerbing Permanent Controller on a KGT1300.
Please note that the way I mounted the controller requires drilling of the side panel.
It is a very straight foward connection process with or without a fuse panel.
The connection process shown installs the controller to the Centech fuse panel. Note that the Gerbing's product provides a fused power connection.
If you do not have a fuse panel you can still do this install, just connect the product directly to the battery terminals and you will not get any dash warnings.
Everything you need to install is provided by Gerbing with good instructions that are easy to follow
Preparation
I removed the top and side plastic to have access to the work area.
Please reference this link to remove the plastic
The tools for this job were:
  • Small screw driver
  • Heat Shrink
  • Heat Gun
  • Electrical Crimp Type connectors
  • Wire wrap (optional)
  • Double sided tape (industrial grade)
  • Drill Bits
  • Electric Drill
  • Masking Tape
  • Caliper and ruler
Mounting location for the Main Controller
Locate the controller under the platform supporting the ABS Unit - Clutch side
Rear View of pre-mount position showing how the wires are being routed.
The ones going up (green arrow) are the power wires which will be connected to the battery; the other (left) are the wires which go to the electric gear.
The thin wire sticking out at the 9 o'clock postion (yellow arrow) is the wire which will connect to the on/off switch.
Now that the cables are roughly fit - it is time to start mounting the main module.
Here is the industrial strength double sided tape I used
Cut off a piece approximately the size of the bottom of the module
Before you apply the tape make sure you clean the contact areas with alcohol so that there is a good adhesion of the tape.
When dry apply the tape.
Mount Module - yellow arrow showing location selected
After mounting the module there is some wire management to be done prior to hard wiring
Securing the power side:
The photo illustrates tying off the power cable to some wiring I'd added to the bike earlier. If you're working on a stock bike, I'd suggest securing it to the brake lines - with not-too-tight tie-wraps
NOTE - as I already had a power connection I plan to splice into it
Connecting the power
Please note that by cutting into the original harness you will void the Controller warranty
For a stock install you have 2 options:
  1. If you do not have a fuse panel of any kind follow the manufacturer's instructions to connect directly to the battery
  2. If you have a fuse panel connect to it at the appropriate current range (fuse), remember this device already comes fused with 15A fuse
Once the power line has been routed I connected the orignal cable from the Centech to the new wire.
Part of the process includes cutting out the newly supplied in-line fuse (as I will be utilizing the previous contact point on the Centech panel (15A))
Shop Tip 1 - add a small piece of shrink tube to identify the power side of the wire.
Shop Tip 2 - pre-positioned a piece of shrink tube before crimping the ends together
The wires crimped - now to shrink over to provide some weather protection.
