Does anyone have experience removing the rocker covers on the R25/2 or R25/3? I am having trouble getting the intake or rear cover off. It contacts the upper frame and doesn't allow enough tilt or rotation to get up and over the rocker blocks. I've looked at this dozens of ways and have gotten suggestions from others, all of which have not panned out. Here's a working picture:
My frame doesn't appear to be bent. I made a measurement directly in line with the valve cover stud. I measured from the top of the head (not the raised edge which the valve covers and gaskets sit on) to the underside of the upper backbone. I measured 105mm. I'd be curious if anyone can make a similar measurement for a similar bike. I'm not sure the R26 or R27 are the same geometry.
At this point, I'm down to two options. Remove the valve cover stud...double nut it and turn it out; or lower the engine. The former is much easier to do, but that just seems wrong to have to do. I know BMW didn't design it this way.
Thanks for any insight...
