bluecycle3
I would like to know what time frame were the valve seats suspect on the airheads? What was the fix? cost? etc... thanks greg
The fix is all cases is new seats and depending on the rest of the top end, new valves and guides.
CD2, a fake lead additive has very nearly stopped all valve recession in my R100/7'78 model year for 10 years now. I have some remarkable proof in an engine with way over 300000 miles with the stock valves still in it!!! I found this stuff about 10 years ago in an auto parts store and its concentrated, using only a half ounce per 9 gallons of gas. I have a 9g Heinrich tank. ALL said is true about valve recession, so beware of it. My suggestion above has worked too, for mine. This is an exceptional case, with all these miles and stock parts still in the engine. I bought the bike new. Randy
Oh, it will be new exhaust valves for sure on the early '80s models.
This from my '84 RS at ~60K miles
The risk was that the knife edge of the exhaust valve would eventually collapse, the valve would be sucked up by spring until keepers fell off and the remainder of the valve then could collide with piston.
This bike was properly maintained and clearance increased to .020 as recommended.
This condition can be inspected through the exhaust port with headers removed.
Lead has been blended with gasoline, primarily to boost octane levels, since the early 1920s.
Lead is and always was a scam and was never required to "protect" anything.
http://www.thenation.com/doc/20000320/kitman
Isn't Marvel Mystery oil like kerosene?
