Results 1 to 15 of 21
Thread: Looking for suggestions
    Aug 2008
    Kingston, NH
    For mounting my new to arrive speed pass.
    My goal would be to have it hidden as I do not want to mess up the front of the bike with that garsih peice of white plastic.
    I was thinking under the cowl covering under the windshield
    Here is the cowl:
    And i would velcro on here:
    Pros/Cons/Other suggestions?
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Tiverton, RI
    Cannot tell from this picture if you have a tank bag or not. I use mine daily for work, and I keep it in the clear map compartment where it has always worked. I know 2 people that mounted them to the wind screen and had them blow off. I believe cycle gadget sells a bracket for them to Perm mount to the bike.
    www.OceanStateBMWriders.com
    Aug 2008
    Kingston, NH
    No tank bag - don't like any of the options for the KGT.
    Would have been great if they did the same system as the RT.
    Will check out cycle gadgets - thanks
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Tiverton, RI
    Aug 2008
    Kingston, NH
    Now that is service
    2009 G450X White
    IBA #35651
    Rogue Moderator
    tourist
    How about mounting below the license plate on the plastic? That way if for some reason it doesn't pick up and a photo is taken. You would atleast be able show you had it in plain view.
    Aug 2008
    Kingston, NH
    good idea - just want to deal with the beaurocratic dealings to explain i have the device
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Jul 2007
    Evansville, WI
    If it would work under the piece you want to mount it under, it might work under the front half of the battery cover?
    87 K75S, bought new, now sold
    13 C650GT
    MOA 44606
    Rally Rat CATHDEAC's Avatar
    Nov 2006
    Round Rock, Texas
    On my 05 LT, I removed the front of the dash... behind the windscreen...
    I zip tied on top of the "down bar... support" then replaced the cover...
    Been working fine for 3 years..
    Aug 2008
    Kingston, NH
    Quote Originally Posted by cathdeac View Post
    What is the battery life on these units?
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Rally Rat PAULBACH's Avatar
    Dec 2005
    Quote Originally Posted by Semper_Fi View Post
    Hard to say - my current E-Z pass is still working after four years.
    Aug 2008
    Kingston, NH
    That is great!
    Is there a low battery warning?
    As you can tell I have not gotten the parts or the manual.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    He Who Rests Rots! pfiedler's Avatar
    Apr 2009
    Boxford, MA
    Luis,
    I found a great little suction device specially made for the MA (and other states with the same device type) FastLane transponders. I slip my FastLane into the holder and then tuck it down on the Aeroflow laminar deflector (which is kinda/sorta like the BMW one) and stick the 3 little suction cups down. You can't see it through the windshield (it's black) and it works perfectly...even at the nasty toll booth in Hampton on RT95 that NEVER use to read my transponder no matter where I had it...even between my teeth!
    I'll try and remember to unbag the K tonight and take a snap of how this is set-up and post it here for others as well. I bought the thing on Amazon:
    http://www.amazon.com/Ez-Pass-Electr...4691823&sr=8-2
    It comes in black...be sure to order that color so it hides well.
    Again, this is mounted to an Aeroflow shield. I know you were thinking of one of those (they're incredible by the way) and not sure if you made the move to one or not.
    Please ride safely!
    Peter
    Aug 2008
    Kingston, NH
    That sounds interesting Peter - I got the transponders last night.
    Depending on how cold it is this weekend may poke around for mounting areas.
    Anyway send a picture of yours for comparison.
    Luis
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Apr 2009
    Boxford, MA
    Here's the picture of my FastLane transponder mounted to the Aeroflow laminar deflector. I had a few more shots (from the front showing that the transponder is very hard to see through the shield) but I can't figure out how to post more than one picture!
    Can anybody provide a hint?
    Let me know if there are questions. Works great!
    Please ride safely!
    Peter
