Results 1 to 10 of 10
Thread: rear wheel hub
Hybrid View
    Atomic City Boxer 154048's Avatar
    Nov 2009
    Santa Fe, NM
    rear wheel hub
    I had one of those 'what was I thinking' moments yesterday. I was cleaning and re greasing the rear wheel splines on my 100RT and used gasoline on a toothbrush to remove the old grease. ( no ignition sources in my work area, so I won't be reporting a burn down).
    I usually use parts cleaner or similar so as not to leave residue, but I had some gas from my recently emptied float bowls, so...
    Question. In using gaso with about a 5 minute dry time before applying moly lube, have I risked degrading the grease?
    Should I just take it apart and re do, or do I have some miles before I pull it apart again ?
    Thanks,
    Steve
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
    --Tony AnnapolisAirhead's Avatar
    May 2007
    Watkinsville, Georgia/Annapolis, Maryland
    Quote Originally Posted by 154048 View Post
    I would definitely take it apart and redo it. Gasoline is great as undoing all the good that we use grease for on these bikes. Its cheaper to do it now, than discover the horrors that could develop over a few hundred miles or no lube.
    1971 BMW R75/5 | 1975 Moto Guzzi 850T Cafe | 1983 BMW R100RS | 1988 BMW R100GS
    1988 BMW K75 | 1998 BWM R1100RT | 2000 Moto Guzzi Quota 1100ES |2002 Moto Guzzi V11 LeMans
    Apr 2007
    Nacogdoches, TX
    What, precisely, is it about gasoline after it has dried that would cause harm in the hub ?
    '08 BMW R1200RT
    Yarddog
    It dilutes the grease when it is wet...and the grease stays diluted...I agree, if gasoline or any other solvent has gotten into your lubricant, redo the lubricant.
    Liaison 20774's Avatar
    I would think that after 5 minutes of drying, there would be no gas residue to deal with. Seems like it would be OK to me.
    May 2007
    It may not cause any problems, but its worth doing it right and having confidence in it. Besides, it's not really that difficult. Would you assume its all gone if you did the same to your input spline? I wouldn't, but that's just my opinion. We all have them.
    I'd be willing to bet though, that if you spill gasoline, wipe it up and wait 5 minutes it'll still smell like gasoline--for a good reason. There is still some there.
    So, my response to the OP's question: "In using gaso with about a 5 minute dry time before applying moly lube, have I risked degrading the grease?" ...is yes. To what extent is not relevant to me, I'd just redo it right.
    To each their own.
