Results 1 to 8 of 8
Thread: smoother shifting after trans lube change?
    Nov 2009
    Metro Atlanta Georgia
    I changed the oil/filter, trans and diff lube yesterday. Only had time to do that and have several other things to do, i.e. spline lube, fork oil, brake fluid, etc., for a complete service. I used some unused/unopened Lubro Moly Voll-Synthese 75w90 left over from my Audi diffs service.
    Even in <50 degree temps yesterday afternoon I noticed the trans shifting was a lot smoother and in 100 miles of back roads riding I only hit one false neutral. The shifting is smoother in both up and down shifts. Only thing I can think of for this before attributing any magical lube qualities to the Lubro Moly is the previous lube was 75w140 lube.
    Anyone else ever notice this with a change of the trans lube?
    Frank
    '86 K75C a.k.a Magic Carpet
    Nov 2009
    The other possibility was it was a placebo effect which was my first thought when I noticed the difference. But after the several series of downshifts I was sure that wasn't the case and the difference was real.
    Frank
    Spring Lake NJ, USA
    I've certainly felt a difference in shift quality with different lubes. Since the weather is cool, a lighter weight lubricant might well make the bike shift smoother. Conversely - I found on my former K75S it was much happier in the summer with the 75W-140 BMW Synthetic.. less crunching/clunking on shifts. I suspect the 75W-90 just thinned out too much when it got hot and let the gears spin down too quickly.
    South Carolina
    mine shifts much better since I switched to Mobil 1 Syn 75-90.
    AKA SNAPGADGET
    Lifes too short to ride an ugly Motorcycle
    Nov 2009
    ... less crunching/clunking on shifts....
    Precisely what I'm seeing now with the new lube.
    Frank
    Oct 2008
    Laurel, MD
    I would like to tackle a trans gear change tomorrow. I am not sure what is in there now but I suspect it is the original fluid or at least some OEM type.
    I would like to go synthetic. What exactly am I looking for and where can I get it from? What quantity will I need? As for the rear diff, is there a substitute to the BMW OEM stuff? Is so what is the details on that?
    Thanks,
    Todd
    1994 K75/2
    Owner/Designer, LampOneDesigns.com
    Quote Originally Posted by toddlamp View Post
    Thanks,
    Todd
    Brick K Bike, right?
    80w90 non synthetic or synthetic, or 75w90 synthetic. 75w140 synthetic is an acceptable substitute. Must have API GL5 rating. 850cc capacity.
    kayseventyfive
    My only complaint is the 1-2 upshift. It is grunchy unless done slowly at a low shift point.
    Is that the worse shift in the box design, or is it the first to show a problem?
    Does anyone think a lube change would show an improvement on just that one shift?
