Page 13 of 14 FirstFirst ... 3 11 12 13 14 LastLast
Results 181 to 195 of 196
Thread: Harbor Freight Motorcycle Lift
  1. #181
    Mansfield,MA
    ^^^^^^Very nicely done^^^^^
    Mod Squad
    2009 F800GS 1994 TW200
  2. #182
    Dec 2010
    Boston
    Great job, please show a pic with the lift down.
    On a side note if you spill gas in your garage the fumes will settle at the lowest point.
  3. #183
    Mansfield,MA
    I just received a new catalog....super coupon makes the lift $299.99 again.
    Mod Squad
  4. #184
    Nibley, UT USA
    I have a Handy lift recessed into the garage floor and an air line running under the floor to the lift. Doing so has positives and negatives:
    POSITIVES:
    1. Other vehicles (car, etc) can park directly over it, being mindful of the wheel clamp or chock or using a removable chock.
    2. Easy to load a bike onto the lift.
    3. Bike can be parked and left on the lift.
    4. Reduced trip hazard in garage.
    NEGATIVES:
    1. Loss of 7 of lift height means new contortions in order to be able to see/work on the underside of bike.
    2. Lift not easily moved for temporary reconfiguration of workspace.
    3. Lift tends to walk inside the pit so clearance and positioning must be monitored. Fix discussed below.
    4. Bolts, washers, and other dropped items like to hide in the pit.
    #3 is probably not an issue with the HF lift. For the Handy I fixed negative #3 by dropping a sheet of 1/8 steel plate into the bottom of the pit then welding down a couple of lengths of angle iron to trap the fixed foot of the lift so it couldnt move longitudinally in the pit. Right now I have a friends identical lift stored in my garage and Ive been using both for various jobs. I suspect that if I ever did it over again I would NOT sink the lift into the floor but would instead fab a couple of removable plywood platforms that could sit on the floor on each side of the lift. That would ease the loading/parking instability risk but still allow full height of the lift and full access with the temporary platforms removed. Plus, Id probably fab an extension to the ramp to flatten out the angle a bit.
    YMMV, of course.
    DGerber
    1983 R80ST 1984 R80 G/S PD 1993 R100GS 2004 K1200GT w/Hannigan S/C 2010 K1300GT
  5. #185
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    I have a Handy Lift as well and have considered recessing it into the shop floor, but your experience has changed my mind. I have ample room and so far have no issues with loading and unloading bikes. Having the wings mounted helps greatly. I would really dislike losing 7 inches in height. Thank you for your post.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
  6. #186
    DBLUPPR snookers's Avatar
    Jul 2010
    Niagara Wine Region
    Well fellas losing 7 inches of lift is a fair trade off for NOT working off of the floor IMHO. And my in the floor lift used to walk inside the pit but after placing some well positioned spacers and blocks it returns to its parked position every time
    Id do it again in a heartbeat
    2000 R1100RT
    Niagara BMW Riders #298
    BMWMCO #45
  7. #187
    I have a ceiling height issue that limits how high I can raise the lift table anyway for a couple of our bikes with somewhat tall windscreens. Given that limitation I don't see much downside for me sinking the lift to level with the concrete floor.
  8. #188
    Jul 2010
    Niagara Wine Region
    Thanks Paul......I'm there as well.......
    Many DIY's have one of those mechanic's stools in their garage,you know, the ones Harbor Freight carries, and using this wonderful piece of equipment, especially during the cold winter months when working beside the lift can and has made the tasks at hand more enjoyable, not to mention reducing the clamping action of a chilled behind.
    also having had tack welded the nuts for the wheel chock and front wheel stop to the underside of the platform makes removing same much quicker as well.
    I think that, as far as the RT is concerned, that losing the 7 inches in height is of no consequence as it is a tall bike to begin with, and had I left the lift sitting on the floor, the chances of working at it's full height would have been slim.
    2000 R1100RT
    BMWMCO #45
  9. #189
    Registered User dbaliko's Avatar
    Jun 2010
    Flower Mound, TX
    Im picking up a Derek Weaver Lift next week. Im local to their Ft. Worth facility, so I can just pick it up.
    https://www.derekweaver.com/bikers-g...eaver-tx-1000/
    Doug
    Doug
    '12 R1200RT - The Green Machine
    '07 R1200RT - (sold)
  10. #190
    Jul 2010
    Niagara Wine Region
    Quote Originally Posted by dbaliko View Post
    Doug
    Great looking lift.......in fact.....it appears to be pretty much the same as the one purchased for our garage. Price isn't bad either
    2000 R1100RT
    BMWMCO #45
  11. #191
    Jan 2005
    Sioux City, Iowa
    Doug
    I bought the drop tail version 3 years ago and love it. The drop tail is great for clutch work or fork work if you back the bike onto the lift.
    I built plywood boxes for each side to help load bikes handy for tall or heavy bikes.
    Chuck Swenson
    MOA # 9162
    2010 R1200RT (BMW #12)
  12. #192
    RK Ryder
    London, Ontario
    Quote Originally Posted by snookers View Post
    Looks as if I have the same lift as you Snookers, complete with the side pieces.
    Before next riding season I am going to build a short box to attach to the left side extension. I ride the bikes up onto the lift and the only place where I have difficulty dismounting from them is when they are parked on the lift. I believe, at least for my legs, the left extension doesn't extend quite far enough from the bikes for me to get off.
    Anyone else have this predicament?
    Paul
    Niagara Riders & Knights of the Roundel #333
  13. #193
    Yes - I use a short stool which is about 8 inches tall.
  14. #194
    Mansfield,MA
    New HF catalog has arrived. Page 3- back on sale $299.99
    Im happy with mine. Planning on adding wings for the ATV.
    Mod Squad
  15. #195
    Jan 2016
    Central Illinois
    Wings
    Red Bull?
