beemermyke
2004 1150RS with 65k on it, noticed this morning that all of a sudden the driver's information display is blank. The backlighting works on it, but there is no clock, gear indication, oil temp, fuel, nuthin'! I remember catching a glimpse of the fuel level display, but as I left the house I looked down and noticed everything was gone. Just as a background: Removed my tank two weeks ago before a big trip to put a new battery in it, and I washed the bike yesterday using S100 bike wash for the first time. I was careful to keep the spray away from anything electrical, as the instructions warn. I did a few obvious checks, like disconnect the electrical connector for the gas tank and where the display plugs into a block on the frame, but found no evidence of moisture in these areas. Is there a fuse for this that I'm overlooking? Do these units fail? As far as running electrical checks, I am getting power to more than one of the pins where it plugs to the display itself, but don't know specifically what wire does what.
