A
awshucks
Sorry to be a pita w/ this. Once you have the steel washers on, then the eccentric w/ small side out, put fairing on these, add the 2nd rubber over small part of eccentric, how do you keep the slotted 'clip' on that slides on turn signal stalks while fitting over the 2nd rubber washer?
Does the orientation of eccentric come into play here? Tnx!
