BouncinBob
Encumbered by employment
merrittgene said:(I ended up cutting the end off and crimping some spade connectors to it, and then bypassing my BMW plug recepticle. Lesson: carry extra crimp connectors in addition to the Leatherman.
Now, if you look at my bike, where the seat meets the tank you will find 1 Widder connector and one gerbings connectors. These run straight off the battery. They are there for 2 reasons:
1) So I don't need to find nice people in motorhomes. i.e. back-up.
2) When it gets REAL COLD, like 0 F ambient, I pull off the heat troller and extra cord and plug the gerbings jacket straight into the backup plug. This gives the little bit of Wattage the heat toller uses to the jacket and shortens the cord lowering resistance and runs all the way from the battery on heavier gauge cord. You'd be surprised how much more warmth you can get when it is actually cold out.
All that said, I've had Widder, it all dies and the Gerbings warranty can't be beat. My arms were cold, the bottom of the arms when I used the arm chaps. Widder is dead right about the heat transfer when the garment is tight. Therefore I have a tight long sleeved T shirt I pull over the Gerbings to snug it to me.
Ahh, heat.
