Results 1 to 7 of 7
Thread: Starter Button Broke Off
    Jul 2007
    New Jersey
    I guess you can't complain when a plastic part breaks after 25 years of use. After noticing that the button was missing, I turned the key to see if I could still start the bike. I turned the key and the bike started ... without hitting the starter. It has been 70 degrees this week (in October ?!) so I did a couple of long rides. With one exception, the bike needed the starter pushed to turn over.
    Here is the question. If the starter is stuck in the depressed position, is the starter spinning away as I am riding? Will I have a burned out starter if I ride it while waiting for the part to come in?
    Quote Originally Posted by zoridog View Post
    If the switch is stuck on - yes!
    Spring Lake NJ, USA
    Paul,
    Actually on a K bike - there is a starter inhibit circuit that won't let the starter turn once the engine starts. If you remember the Lentini CO adjustment - where you used the starter button to enrichen the mixture momentarily with the engine running.
    Somehow BMW lost their way with the oilheads and didn't include that feature - but they managed to remember it for the hexheads..
    Paul,
    Yes, I do (now) remember that. I hate it when I screw up like that.
    Jul 2007
    Evansville, WI
    I know if you push the start button with the engine running it won't operate the starter motor, but if the button is never released, will the starter actually stop running?
    87 K75S, bought new, now sold
    13 C650GT
    MOA 44606
    Apr 2005
    Rapid City South Dakota
    K-Trivia
    The starter interupt circuit is in the relay ground that goes through the ignition black box. I have an 85 that would start to crank and then stop cranking before it started. It sounded almost like a old ford kicking it's out its bendix. The diagnosis was to find the ground on the relay and directly ground it and the problem went away. and of course the starter interupt went away as well. I then replaced the black box with a known good black box and have had no further problems.
    I mention it because it was trivia to me untill I bought the bike because it was frustrating the PO. Then it took months to connect the trivia to the problem.
    Harold In Rapid City, SD
    1985 K100RT Bullit
    1985 K100XX/EML Bemel
    Jul 2007
    New Jersey
    Thanks, now I can go to the 3 club rumble tomorrow!
