Results 1 to 11 of 11
Thread: timing Chain Question
    habdala
    Doing timing chain here is the question:
    Replace crankshaft sprocket or not?
    And do original chains have a link?
    Thank you!
    Bill the Cat geisterfahrer's Avatar
    Aug 2009
    Rochester Hills, Michigan
    WOW, that is CLEAN! How did you get everything so thoroughly degunked?
    I'm no expert, but to my eye, that sprocket does look quite worn. Conventional wisdom says that if you replace one component in a chain system, you should replace them all. So, you should replace the crank sprocket, cam sprocket, and timing chain all at once.
    Older style chains did not have a link, so you have a choice of pulling both sprockets and the chain all at once, or just cutting the chain. You can buy endless chains, or chains with the master link.
    Call Hucky for advice and parts.... this is the link to his front page, just find the group with your bike, and look up section 11.
    Looks like you have simplex (later) chain.... you will see pics on his website. I personally find the pictures a big help...
    habdala
    Quote Originally Posted by rpeckham136133 View Post
    Well in that picture is a new chain but the old one had a link, the PO (only owner) told me he never replaced the timing chain and I don't know if the original chain comes with a link.
    I don't see the link for Hucky
    Bike is a 79 R100RS
    thank you!
    The single row chains used from '70-'95 have a master link. Removing the crank sprocket is dificult; it takes a puller and comes off hard. Replacing it requires heating the sprocket and/or pressing it on.
    habdala
    Quote Originally Posted by lostboy View Post
    Is it a special puller?
    Thank you!
    Liaison 20774's Avatar
    Quote Originally Posted by habdala View Post
    http://www.bmwhucky.com/
    habdala
    ty
    There is a special BMW tool for this job (probably NLA from BMW), but I use a Snap-On 3-jaw puller. If you don't use the BMW tool, put a short 8mm socket-head screw in the end of the crankshaft to prevent damage to it.
    habdala
    I did used the 3-jaw puller and a copper penny to protect the end of the crankshaft, it was a pain but worked fine, now I'm having an electrical problem on another tread.
    Thank you!
    habdala
    Quote Originally Posted by geisterfahrer View Post
    That is how it was when I removed the timing cover.
    Replaced chain sprocket and moving on to bigger things now.
