Results 1 to 4 of 4
Thread: bing carb. question
    bing carb. question
    R80/7 recently purchased came with two prof. rebuilt carbs. ~ owner says they are jetted to standard R75/6 settings. Do they match the settings on my '78 R80/7 and does Bing have a schedule of jetting specs etc...???
    thanks....the ones on the bike are leaking badly and these were hypersonically(?) cleaned and rebuilt...
    thanks once again
    Ray
    Ashland, VA
    --Tony AnnapolisAirhead's Avatar
    May 2007
    Watkinsville, Georgia/Annapolis, Maryland
    The best $10 you'll ever spend is for the Bing Carb manual, you just need to call them to order it. http://bingcarburetor.com/manual.html
    In the meantime, if you want the specs on your current bikes, give me the year, model and the numbers on the carb, should be stamped into the webbing that goes between the bottom half of the dome and the carb body. Something like 64/32/113 and 114 (the last digits will be one apart between the left and the right carbs).
    1971 BMW R75/5 | 1975 Moto Guzzi 850T Cafe | 1983 BMW R100RS | 1988 BMW R100GS
    1988 BMW K75 | 1998 BWM R1100RT | 2000 Moto Guzzi Quota 1100ES |2002 Moto Guzzi V11 LeMans
    thanks~will be calling Bing tomorrow
    1978 R80/7(mfg. 02/78) Bing #64/32/221-2
    the rebuilt carbs I have look identical and have the same numbers.
    the original spec sheet i found shows 64/32/201-2
    The original carbs on the 78 R80/7 were "flat top" bings. Reputedly these provided less precise metering than the dome top models used earlier and later.
