Results 1 to 5 of 5
Thread: Oil pressure switch?
    Went to start La Chica Vieja up last night and no go.
    After trying to start a couple of times I noticed the fuel pump wasn't energizing.
    Found blown fuse, not sure why, but replaced it and now pump energizes.
    But, then I noticed oil dripping at the center stand. Followed it and appears to have come from around the oil pressure switch.
    Could pressure build up from not firing and cause oil to leak there or do I have another issue?
    Also, anyone know what size nut that is (at the oil pressure switch)? It's bigger than anything I have.
    Kev
    Urbana, IL
    Quote Originally Posted by Kev95GS View Post
    Kev
    Those leak sometimes...get a new one. Use a 24mm deep socket. The new one comes with a crush washer. Don't over tighten it.
    My other bike is a BMW.
    Apr 2008
    SW Ohio
    K100, k1100, k75, r1100 r12c & K1 all use the same switch. I was in a bind couple
    years ago and discovered the pressure switch from a 1984 318i fit my K75 perfectly.
    Available most any car part store for $12 or so.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    Y'all rock!
    92K, I reckon it's time. I was gonna retorque it but don't have a big enough socket.
    Thanks!
    Kev
    Urbana, IL
    Quote Originally Posted by 35634 View Post
    Don't torque it! Replace it because it is leaking from the insulated part, not because it is loose or anything.
