Results 1 to 4 of 4
Thread: stickty gas
    chuckie3004
    stickty gas
    i have a 02 k1200lt it seems that when it is cold outside 55 or so the gas sticks it makes the curise stick or shut off any ideas thanks
    Spring Lake NJ, USA
    Heated grips on? If so - the grips are expanding enough to cause binding on the end. Fix is to find the binding and make clearance.
    Dec 2004
    Winnebago, Il
    Quote Originally Posted by chuckie3004 View Post
    LT's also had a problem with the stock throttle cables failing and making the throttle very difficult to operate. BMW has revised cables to retrofit this problem.
    Other areas to check are the micro switches on the brakes and clutch lever. These have been known to also cause random failures of the cruise control.
    Good luck
    Roy
    Roy G.
    85 K100RT Ol Ruby "Gone but not forgotten"
    02 K1200LTC Hoss "Wrecked on 9/21/14"
    12 R1200RT
    chuckie3004
    Thank you
