E
eddavnct
Bing carbs shot one didn't even take to a rebuild thinking about Mikuni VM34mm any buddy have any info. on what to do with vac. lines my bike is a 84 RS also do they run well on beemers
I just took off a pair of Mikuni VM 34 from a '83R100RT and they ran great! I have them for sale on the flea market. I would put up some pics,but the overseer always scolds me and takes them off.
I put VM-26's on my '74 R60, and they work very well. My originals had no vacuum lines, but I tapped a 5mm hole in each Mikuni for a vacuum port for synchronization purposes.
I put VM-26's on my '74 R60, and they work very well. My originals had no vacuum lines, but I tapped a 5mm hole in each Mikuni for a vacuum port for synchronization purposes. I had to re-jet them [idle jet, needle jet, main jet] and adjust fuel level. The rest of the conversion required new throttle cables, a pair of carb-to-cyl boots, a pair of air tube-to-carb boots, and eight clamps. I shortened the air tubes about an inch each. I removed the original choke/cables, as I have to choke each carb now.
Stan Smith @ Rocky Point Cycles [Xenia, Ohio] sells complete conversions, although I bought my carbs at one source, and the rest of conversion from Stan.
Some pics:
Hope this helps.
Richard
The one that was in Florida it seems has moved to Mass....
