F
fracture
A little help is needed. The bike is a '94 R100RT.
The problem: When the forks extend suddenly, such as when I hit a pothole or on rebound from hitting buckled pavement, I hear a metal on metal sound. The only way I can describe the sound is that it is similar to tapping two metal rods together. It appears to be coming from somewhere near the top of the steering head but hard to tell for sure. No problems when the suspension is compressing, only when it extends.
The forks have recently been serviced. Nothing inside was in need of replacement except for the fork seals. The springs are factory. I think 10 wt oil was used.
With the bike on the center stand and no weight on the front wheel I can detect no movement, no slop, when the forks are moved side to side or front to back. Everything seems tight. I notice no problems in riding. Steering seems to be just as it always was. The front suspension operates as expected when on the freeway or in town. I cannot find anything else that may be loose.
I have not had a chance to do much except have a quick look at the Clymer to see what may be inside the steering head. There may be a part other than the bearings that has worn and needs replacement.
I suspect the steering head bearings are either loose or need replacement. It may not take much wear to cause slop and thus produce the noise I hear.
It could be nothing more than the bearings needing a bit of tightening. I have heard that this may be all I need.
Your suggestions/comments are appreciated.
