Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: Very Functional Shop Tool
    Aug 2008
    Kingston, NH
    DISCLAIMER - I am not affiliated with Pitbull their subsidiaries or anything related to them.
    Just happened to have bought one of their products.
    For those wanting to get the front wheel up for servicing their KGT you need to get a lift, there is one provided by BMW, but as all things Roundel, bring more wallet.
    I ended up getting the pitbull fork lift and it is really easy to work.
    Here's the unit
    Here is the unit in place to lift the front of the bike
    And here is the front lifted up - it went up with one hand, took immediate advantage to clean the front rim!!
    It also went down with one hand - very easy to control, good leverage.
    This cost less that half of the BMW style.
    It can also work on Hex RT's and ST's
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Registered User texanrt's Avatar
    Nov 2008
    Lafayette LA
    +1 It's on my wish list.
    John H | TexanRT | Lafayette | IBA
    BMW K1600 GTL '18 | Honda Goldwing '12
    Registered User DPeakMD's Avatar
    Sep 2007
    Franklin, IN
    Looks slick! Could it be used for tire changes?
    Dallas
    2011 R1200GS Adventure
    Aug 2008
    Kingston, NH
    Quote Originally Posted by DPeakMD View Post
    That is exactly what i bought it for.
    When I need to replace the front tire there is no clean way of lifting the front end.
    You put the bike on the centerstand - clip in and push down on the pit bull and you can easily take the fronk wheel off
    2009 G450X White
    IBA #35651
    Rogue Moderator
    i have one of these for my hp2 enduro... and use it for tire changes. (hp2 has no centerstand...)
    it's very high quality and works well, but you must be very careful in mating it to the forks before lifting. if it's even just a bit out of line, it compresses the fork legs unequally and make it difficult to re-insert the axle.
    this, of course, does not apply to wedgie bikes.
    i bought the front and rear jacks for less than what BMW charges for the single shop stand for my bike.
    ian
    Go soothingly through the grease mud, as there lurks the skid demon.
    __________________________________________________ __________________________________
    '67 Trail 90 || '86 R80 G/SPD+ || '00 1150 GS || '07 Xchallenge || '13 CB500X || '14 Grom || '19 CB500X
    Sep 2006
    CENTEX USA
    I got one last month..I got tired of putting 45lb weight plates on the rear rack of the bikes to do the fronts easily. And before I put the centerstand on the K12S, they sure make life easier. I borrowed a buddies rear one for the EVO drive hole and have one coming next week for use on the other non- centerstand friends that stop by.
    My only lesson was to loosen the axle pinch bolt BEFORE lifting the front forks as it was blocked by the PitBulls cushions ..I think it was on the GSA Only did that once...easy fix, but still a learning curve
    Great product and decent pricing for a long term shop tool
    Jun 2007
    Nice to see it looks like the same model I got for my 2000 K12 - since I am workin toward the new 13S......My question is, do you need to remove the rear wheel before you raise the front? I have 1/2" longer suspension f/r on my '00 and must put it on the center stand on a 2x6, then remove the rear wheel before raising the front. No problem since I noramally am using it to remove both to mount new tires, but I was curious. I assume the special rear axle-hole stand eliminates this issue anyway?
    Jim Douglas '00 K1200RS >138,000 miles -- Black, 01/10/2000 to present
    Gone: White '09 K1300S sold @ 22k mi, Black '93 K1100RS traded @ 78k mi, Red '85 K100RS sold @ 44k mi, '06 Kaw 650R chrome yellow track bike sold http://www.seagullbb.com/
    Aug 2008
    Kingston, NH
    The pictures shown is how I lifted the bike - stock wheels/suspension.
    I put the bike on the centerstand, aligned the pitbull - pushed down and viola.
    The back wheel did touch the garage floor - but there was no pivoting off of the center-stand
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Nov 2005
    Calgary, Alberta
    Nice looking piece!
    Rinty
    perniculous
    I never met a tool I didn't like!
    Pardon my noobness, but are the front tire grooves going from outy to inny? I'm used to seeing that type of tread reverse of that. ??
    Aug 2008
    Kingston, NH
    Quote Originally Posted by perniculous View Post
    ...... but are the front tire grooves going from outy to inny? I'm used to seeing that type of tread reverse of that. ??
    That is set up for water evacuation as the front tire rolls forward.
    Pilot Road 2's have an even more pronounced pattern, almost V like
    2009 G450X White
    IBA #35651
    Rogue Moderator
    perniculous
    That Pilot Road 2 looks edible!
    Aug 2008
    Kingston, NH
    To continue the highjack for one more post - they are my favorite tire.
    When i burn thru my current pair of Z6's I am going to PR2's
    2009 G450X White
    IBA #35651
    Rogue Moderator
    2-up and havin' fun sugarhillctd's Avatar
    Oct 2007
    Just above the Notch, NH
    Hey, nice stand. Need to get front and back for our son's Monster (no center stand).
    Not to hijack, but now that someone else mentioned it- yes, new front tires Do look like they were designed backwards. Check out my front tire.
    BTW, I went from Z6 to PR2 tires also. NOT going back- those Pilot Road 2's feel great on the K.
    (pay no attention to the torn apart K- clutch friction plate and "O"ring plus lots of other stuff. That was a few weeks ago and it runs GREAT now)
    John & Cathy
    '92 K100RS4v 2003 R1100S BC
    SS1000, BBG, 50CC- NYC to SF
    Aug 2008
    Kingston, NH
    Quote Originally Posted by SugarHillCTD View Post
    Very well organized work area - pretty invasive work though!!
    2009 G450X White
    IBA #35651
    Rogue Moderator
