D
dhthorpe
To change pre-load with ESA, the bike must be running, so I assumed more electrical power was needed to compress the springs. Funny thing though, when I cycle through the settings (one helmet, two helmets, etc.), there is no mechanical change on the spring ÔÇö it stays stationary. Even with my hand on the spring, you can't feel anything when going from one setting to the next. Either my ESA is not working, or "spring pre-load" is something other than spring compression. Does anyone know the answer to this?
