Results 1 to 6 of 6
Thread: Rough Idle
    RadRider radrider's Avatar
    Apr 2006
    Weston, FL
    Question Rough Idle
    Does my RT have a problem or is it the boxer engine "hiccup"?
    I have a 2005 R1200RT with 17,000 miles and have really enjoyed it. My last trip was a three week 5320 mile tour including the MOA and RA rallies. Other than 1 qt oil consumption and nearly overheating at the MOA ERC course, it performed beautifully. However, I continue to be bothered by the rough idle with occasional "skipped beats", "hiccups" or misfire I feel when cold and after a long ride.
    Do I have a problem or is this the "character" of the boxer engine?
    JoeRadMan
    2005 R1200RT
    Aug 2008
    Kingston, NH
    When was the last time you adjusted your valves and sync'ed the throttle bodies.
    Sounds like you're due.
    If you want to see the scope of work involved check out these DIY's if you haven't already
    Valve Adjustment
    Throttle Body Sync
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Registered User motorman587's Avatar
    Nov 2005
    Florida
    Check the vac. hose on the left side. We have a couple that has this happen where the vac. hose comes lose. Rough idle and back firing etc.........put the vac hose back on fixed. If you need a picture let me know.
    John
    2004 BMW R1150R Black
    Contact me 4 (1&1) training, Expert witness in motorcycle crash reconstruction
    Apr 2006
    Weston, FL
    The bike has had this occasional hiccup since I bought it in 2005. Not really changed since 2005 and techs have not been impressed. Has had all services per schedule with last 12000 mile major service and inspection at dealer last month. I have accepted this as the normal "rough character" of the boxer engine. I recently demo'd the K1300GT and I am probably more sensitized to the vibration and hiccups of the boxer compared to the K engine. Thanks for the advice!
    JoeRadMan
    05 R1200RT
    New2rt
    My 09 will show a bump at idle every once in a while, feels as you describe. Valves and TB sync are dead nuts on. No codes set, no warning lights. Doesn't bother me and the bike runs great so I write it off as character.
    Polarbear Polarbear's Avatar
    Clovis,CA
    Plugs too;
    You can change all 4 of them, but they usually last a very long time, with these new engines. My idle does the same thing, since new and I know its spot on, as I do the service myself. Sometimes a simple plug change out will get r done nicely. Once you learn the TB synch process, its a cakewalk at keeping them in synch and not needed very often, once there, I've found with mine. I did the cannister ectomy on my GSA too so the vacume lines are kind a re routed and/or discontinued. That charcoal cannister can be a pain in the rear and needs to be bypassed, if you've not done it already. KEEP IT, however, for emmisions laws may change and inspections and so forth may be coming down the pike. Randy
