Daedalus214
Bus issue redux
The prior explanation regarding the GMC Bus was from the dealer (Not sure if this is the most reliable source....). These new bus systems are far more software dependent than the older systems.
Again, I think that if the undersized alternator was on an older model vehicle, either the battery would drain, or all the systems would equally be deprived of current (though the resistance grid requiring a larger load may see a larger drop off in current), or both would occur. And, unless one knows how the new bus is intended to operate, one can easily get into trouble adding farkles or working on these systems.
