Results 1 to 15 of 26
Thread: Looking to switch...
    I work too hard.... ARM74's Avatar
    Haslett, MI (near Lansing)
    After 10 years with an oilhead, one ride on a new KGT and I'm hooked. What a great ride! I know I'm not saying anything most of you already know, but I was just blown away.
    My questions:
    1) In general, is the K12GT "easily" serviceable by the home wrencher? My R1100R is really a piece of cake as far as routine services. Even a spline lube is doable with enough information and time. Can fluid changes, valves, tires and basic electrical maintenence be done in the driveway or is the GT the kind of bike that always needs the dealers attention (even for the easy, routine stuff)?
    2) Any major issues I should be aware of when looking at an 05-07 K12GT? I'm not looking for reasons to disuade me from a purchase, I would just like and idea as to what I can potentially expect. Are splines and issue on this model? What about final drives? Coming off of 10 years with an oilhead, I'm quite familiar with spline issues and such. Just wondering if these things persist with the K as well.
    Thanks in advance for any input. I hope that by Christmas time I'll be posting a photo of my "new" KGT.
    2007 K1200GT
    -Leave the gun, take the cannolis.
    Aug 2008
    Kingston, NH
    Quote Originally Posted by 86755 View Post
    That was my same reaction when I test road the bike - jaw on the floor, not from the speed but the complete package.
    My questions:
    Over the weekend I took all the plastic off since i was wiring in my Zumo/Autocom/XM Antenna - from the looks of it:
    - Front brakes - doable
    - Read Brakes - doable
    - Oil and Filter - different from the RT but doable with a revised process
    - Rear drive - doable
    - Air Filter - doable
    Things that would need further investigation:
    Valves
    Radiator Fluid
    And tranny - just because I did not look at it
    Too new to the GT to provide assistance in the years your looking at.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Good to hear. Thanks for the info.
    And you're right about the complete package. Its a great machine.
    2007 K1200GT
    Urbana, IL
    Quote Originally Posted by Semper_Fi View Post
    Valves
    Radiator Fluid
    The valves need to be checked at about 18K first time. I have yet to hear of any needing adjustment. The radiator needs to be removed (simple) and the fluid replaced by drawing a vacuum on the system (this is done with a tool that uses air pressure to draw a vacuum) and presenting the fluid to it (too many nooks and crannys?). The transmission is a cassette type inside the engine on the left side and shares the engine oil with the rest of the engine.
    R1200GS LC Rallye
    Aug 2008
    Kingston, NH
    Quote Originally Posted by cjack View Post
    thanks Jack - much appreciated
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Jul 2007
    Evansville, WI
    Oil and filter (which includes the trans) no problem. Tires no problem. Brakes no problem. Basic electrical maintenance I am confused about. Replacing battery is a snap. Adding to system can be hard due to Can Bus system. Will probably need dealer for brake flushes, coolant flushes, and anything where the cooling system is opened (see CJacks comments). Radiator comes out for valves and spark plugs as i understand it.
    Splines I have NOT heard of any issues, but the problem with the final drives are well-documented. I think more so on the 1200's due to the higher hp. Some complain of fueling issues, which continue on to the 1300's I guess. Most everything can be fixed with updates, so will be better to find a newer bike with warranty remaining on it. Problems with antenna rings around the ignition switch (driver authorization system), there is a recall for that. Center stands breaking. People unhappy with riding position and wind protection. I think it's worth it, at least so far, what a ride! Find a Dk. Graphite one, that's the FAST color.
    Check out this site:
    http://www.k-bikes.com/forums/index.php?
    Thanks in advance for any input. I hope that by Christmas time I'll be posting a photo of my "new" KGT.[/QUOTE]
    87 K75S, bought new, now sold
    13 C650GT
    MOA 44606
    Aug 2008
    Kingston, NH
    Quote Originally Posted by Gilly View Post
    1) ..... Adding to system can be hard due to Can Bus system.
    Not really - the Canbus can be by-passed with any fuse panel aftermarket item
    Popular ones are Centech and BlueSea and there are others provided by Touratech.
    Personally I like the Centech due to higher current capacity.
    I just added one to my GT - peice of cake, same as it was on the RT.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Rally Rat PAULBACH's Avatar
    Dec 2005
    Another fuse possibility
    Fuzeblock <- Check Out This Link
    I have installed a couple of them on my bikes. Super easy to install and no external relay required since it is all in once neat package about the size of a pack of playing cards.
    Urbana, IL
    Quote Originally Posted by PAULBACH View Post
    That's a nice item. I like the option of switched/unswitched by changing the position of the fuse.
    R1200GS LC Rallye
    Jul 2007
    Evansville, WI
    What I am attempting to get across is that it is not like trying to add things to a non-Can Bus bike. SURE you can do it, but not without modifying/adding things JUST to do it. You need to always take the Can Bus in to account. I never said it can't be done.
    Gilly
    13 C650GT
    MOA 44606
    Urbana, IL
    Gilly
    Your point is well taken and understood. The sensitivity in the "can bus" bikes (which has nothing to do with having a can bus) is that when you add extra loads to a circuit or take loads away from a circuit, the chassis controller throws a fault. In the case of the earlier non can bus bikes, the additional load, if not exceeding the fuse rating, would not be noticed. As well if you disconnected or burned out a lamp, this would also not be noticed unless you looked at the lamp.
    So the difference is that the can bus bike is more exact and notifies you on what current the circuit is supposed to draw over a narrow range whereas the bike with the fuses is somewhat sloppy on the matter of normal current draw. And for most things, does not notify you when things are abnormal.
    So naturally, to add or subtract things (current loads) you must either leave the existing circuits alone and create new ones directly from the battery, or know exactly what you are changing and how to do it so the existing circuit doesn't detect a change outside of an acceptable range.
    So I would say the first way is easy (as did Semper_Fi), and the latter way is as you say "hard"...probably...for most owners.
    R1200GS LC Rallye
    Aug 2008
    Kingston, NH
    Gilly
    Gilly - i was responding to your statement that it was hard to get around the CanBus - I stated it was not for the reasons I gave.
    With the new bikes and cars with the single wire system you must take it into consideration
    CJack - very thoughful and complete response as always
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Forgive my ignornace, but what is the CanBus system exactly? From what I've read above it deals with power distribution among various electrical systems.
    2007 K1200GT
    Urbana, IL
    From http://en.wikipedia.org/wiki/Control...93area_network
    "Controller‘«Űarea network (CAN or CAN-bus) is a vehicle bus standard designed to allow microcontrollers and devices to communicate with each other within a vehicle without a host computer."
    The bus is just a twisted pair transmission line with a ground shield over it that runs between the various computers on the bike (something like five of these computers depending on the model and extras). That way the engine management computer can communicate with say the display unit computer and share info like the bike's mileage for example. However the issue we have to deal with when putting farkles on these bikes is usually the ZFE which is the central chassis controller. The ZFE controls most all the current loads for lights, etc. and shuts down these circuits if the current exceeds certain limits. For lights, if the load goes away like the lamp burning out, the ZFE sends a warning to the display unit via the can bus...so that's the only place the can bus gets involved if you are messing with these existing circuits.
    Naturally, if you put an additional circuit on the bike directly from the battery, turned on and off with the ignition with an added relay AND the current to operate the relay is drawn from a circuit which will tolerate another say 100ma or less...there will be no issues with the ZFE or messages from the can bus about it.
    R1200GS LC Rallye
    DWR302
    KGT magic...........all I can say is go ahead and get one. But only if you really like
    the killer power and fantistic handling. I traded in my 08 RT on the K13GT. Took it back up to NC and hit the good roads, the Dragon, etc. that I had run on the RT.
    The RT was great but being a power freak I like the GT better. 3600 miles in a couple months and no problems. Like any piece of hardware, getting one with some warranty still on it is always a good idea.
