Results 1 to 2 of 2
Thread: Starting problems ?? on 2004 R1150GS
    Registered User sarelp's Avatar
    Jul 2008
    Jasper, IN
    When I go to start my bike in the morning the fuel gauge and thermometer go on but then go off and keeps doing it. I can hear the fuel pump go on and off and on and off, and its not right. Once i get it to stay on and start, it doesn't do it again until the next morning. Has anyone had this problem before?
    JANMILLER
    Similar, not exact.. Last year, 2 blocks from home, '04 RT died. Hosing down the ignition switch via the key opening (enough runs down eventually to reach the switch) cured it for a while. This year, it began intermittent off/on's, and failed entirely near the rally.
    I suspected the switch, but wanted to be sure so allowed it to 'self-diagnose'.
    Ignition switch was bad. Replacing it cured the problem, for $105, but the quality is Very Low, so expect it may happen again down the road. Semi-Easy to replace, PM me if interested....
