mike cousino
Search = zip
Finally getting my hitch installed and need to wire to the plug. How did you guys
do it?
We have an '09 GS and because I have the Adventure rack, getting under the tail
section is a major task. So I've removed the tail light and can get to the wires
there. In testing I found the brake light wire has about 2.5v to it when the key is
on. When I hit the brake there is the full 12v.
I was planing to install relays, one for each turn signal and one for the brake light.
The tail light will run off the Centec. The relays will be triggered by the bike's light
and the relays will power the trailer lights through the Centec.
-Will the 2.5v cause the relay to chatter?
-I know Uni-go makes a wiring harness for the Canbus, it's over $100. Is itworth it
or should I just go ahead and make my own up?
do it?
