OK, on a serious note, Paul Glaves points out in this months ON that most automotive oils have had the zinc anti wear additives ( ZDDP) greatly reduced (on any thing rated above SG) to protect catalytic converters.
This lack of zinc causes problems with flat tappet pushrod engines (cam and lifter wear). We have overhead cams so are not as affected by this problem (sorry Airheads).
If you want to be extra safe you can buy zinc anti wear additives (I use one by Red Line Oil). I use 1/3 bottle per oil change. If I remember correctly, it's around $12/ bottle. (I want to get 350,000 miles like Paul).
http://www.redlineoil.com/products_motoroil.asp?productID=122&subCategoryID=1&categoryID=1
