Results 1 to 15 of 19
Thread: Bing 53 carbs
    DS74BMW
    Bing 53 carbs
    I am new to the BMW MOA, and new to BMW bikes.
    I just purchased a 1974 R60/6, with 51k, but have had motorcycles, off and on, since 1967.
    I am restoring a 1980 Velorex 562 sidecar, and the R60 seems like a perfect candidate for this.
    The previous owner of the R60 had gone through a number of mechanical systems, as well as some cosmetic improvements, to make this a reliable bike. It still has room for improvement, but overall, a nice classic machine. It started well, ran out nice, new tires and battery, so I brought it home.
    After all the paperwork, tags, insurance, I took my first ever ride of about 40 miles yesterday. Upon arriving home, the left carb began leaking out the bowl overflow, so I removed the carb to clean, check the float needle/seat, and float level. As my Clymer service manual has not yet arrived, I pulled a diagram off a site for info.
    I have two questions: the idle jet had the rubber o-ring wrapped around the threads. Where is this o-ring placed? The diagram shows this appears to go in first, followed by the idle jet; however, the idle jet does have a groove under the slotted head - not sure of correct placement.
    Secondly, I cannot find what the correct float level should be, or where it's measured from.
    The needle/ seat appeared fine, but the carbs definitely needed cleaned, and the bike still had old gas in it from early spring. I've never worked on Bing carbs, but they seem straight forward - just don't have the specs yet.
    Any comments/suggestions appreciated! Thanks. Richard
    --Tony AnnapolisAirhead's Avatar
    May 2007
    Watkinsville, Georgia/Annapolis, Maryland
    Quote Originally Posted by DS74BMW View Post
    Although a of folks run sidecars on 1969 ( /5) and newer, BMW strongly recommended against it due to the lightened frame. The sidecar is basically doing everything it can to leave the bike. You can do it, but you should look into (at least) a strong subframe support (Tarzan in Pennsylvania can do this) and spoked wheels. The load can crack a cast wheel like a snowflake or Lesters (you might already have this).
    ...After all the paperwork, tags, insurance, I took my first ever ride of about 40 miles yesterday. Upon arriving home, the left carb began leaking out the bowl overflow, so I removed the carb to clean, check the float needle/seat, and float level. As my Clymer service manual has not yet arrived, I pulled a diagram off a site for info.
    Mine did the same thing, even after I'd rebuilt them. I found it was leaking from the fiber wash seal at the bottom of the bowl on the aluminum drain port nut. I tefloned it and all it has stopped (not sure how long that'll last with gasoline, but 3 months so far and no drips). Yours may not have this.
    The o-ring indeed goes into said groove.
    Best $10 you'll ever spend: http://www.bingcarburetor.com/manual.html
    Hope this helps.
    1971 BMW R75/5 | 1975 Moto Guzzi 850T Cafe | 1983 BMW R100RS | 1988 BMW R100GS
    1988 BMW K75 | 1998 BWM R1100RT | 2000 Moto Guzzi Quota 1100ES |2002 Moto Guzzi V11 LeMans
    DS74BMW
    Thankyou.
    I do plan to fab/buy a sub-frame. My bike does have spoked wheels.
    My Bings do not have the bowl screw - I think the fuel was from the overflow. My Bings have the number 1/26/123 stamped on the body
    I saw that manual on the net, and plan to get one, but I could use a float ht dimension now, as I have the carbs off at present. I'm sure the ordered Clymer manual has this info, too, but would like to button it up and ride
    I appreciate the quick reply - again, thankyou.
    Liaison 20774's Avatar
    I've never worked on the Type 53 carbs, but a starting point for float height is to turn the petcock off and drop the float bowl. Then with your finger holding up the float to close off the valve, turn on the petcock. Slowly lower the float until gas just starts to flow. See where the horizontal mold line on the floats is in relation to the bottom flange of the carb body. They should be roughly parallel. Shut off the petcock and make the adjustments. There should be a small tang that presses up on the bottom of the needle valve. Bending this tang will change when the needle valve engages the seat. Don't be hamfisted in working in this area. Too much pressure and you can damage things or break off a mounting flange for the float pin.
    There's another measurement that I'm aware of but it applies more to the CV carbs. One measures the depth of the gas in the float bowl after it's filled and then closing the petcock. On those carbs, the depth of the fuel measured in the middle of the bowl is around 22-24mm...varies a little bit by carb size. My guess is that it's something on this order for your carbs.
    The depth of the fuel is a more precise way of getting the proper adjustment. The parallel test is OK if everything is perfect...the float was manufactured properly and it has the correct bouyancy. Floats age over time and begin to sink.
    DS74BMW
    Thanks, Kurt - good info. I'll check the fuel level on the carb that wasn't leaking, although that doesn't mean it's correct, either, but a place to start.
    I agree, ham-fisted and carbs are not good bedfellows!
    DS74BMW
    The carbs are now thoroughly cleaned, adjusted, and sync'd. I think, after seeing what was in these, that dirt probably interfered with the needle/seat on the left side. The bike is more responsive, starts and idles very well. I had almost forgotten what a pleasure it is working on a twin, let alone one that is superbly engineered.
    Any recommendations for a good on-line source for BMW parts? There are no convenient dealers in my area. I found today, during my work, that the "ring/pinion" type throttle assembly does need freshened up - wear on the "teeth" inhibits smooth operation. I certainly like the design! I really believe this R60 was a good choice for this, and my wife really likes it.
    BTW, a couple pics of my sidecar before I started restoration; the primary reason for this project was so that my wife and I could take our dog with us:
    under restoration:
    May 2007
    Sounds like you got the carbs problems sorted out. Good deal.
    For parts needed from a dealer, I generally reference either maxbmw.com (online catelog) or realoem.com to
    get the specific part numbers, then check maxbmw.com, chicagobmwmotorcycle.com and sometimes Bob's for pricing.
    Chicagobmw has pretty good prices, but you probably need to call them and ask for the 20% discount--and delivery has
    been slow in my experience. 2-3 weeks, so you'll want to make sure it's a good deal cheaper.
    Other vendors I've used:
    Rocky Pointe Cycle
    Ted Porter's Beemer shop
    EU BMW (although not that often)
    Motorrad Electrik (highly recommended, although I've never received a call back-- I think you need to be persistent and hope to reach Rick directly).
    Used parts from
    ibmwr.org (I keep a list of straight shooters I've dealt with and reach out to them first)
    craigslist.com (for local stuff)
    MOA Flea Market
    Hucky
    Reference Sites:
    www.bmwmotorcycletech.info (Snowbum's legendary--hard to read, but amazing advice--site)
    http://largiader.com/ (Anton's site--straight shooting and accurate advice)
    http://www.bmbikes.co.uk/information.htm (specification site, most models and mostly accurate)
    http://www.beemergarage.com/ (Self proclaimed largest number of BMW articles and photos on the net )
    http://w6rec.com/duane/bmw/index.htm (Duane Ausherman's site, good advice here)
    That should keep you occupied for a while. Also, the airheads.org group has good stuff and of course Oak's tech index.
    Nice looking sidecar. Please keep us posted on the progress.
    I've had good luck and great service from Ted Porter at http://www.beemershop.com. He's located in NorCal.
    Vech in Mississippi has mostly /2 parts but has expanded his inventory to include later bikes too. http://www.benchmarkworks.com.
    I've never used Hucky before, but people have said good things about him. http://www.bmwhucky.com.
    Of course, all things electrical can be had at Motorrad Elektrik...http://www.motoelekt.com.
    sumran
    That is a great looking sidecar and fabulous garage. Are you a machinist? It looks like you have some of the equipment.
    I haven't worked on the type 53 carbs but you will get good info from others. The Bing book is money well spent. Some of the information and exploded drawings are available on their website.
    DS74BMW
    Thanks, guys! I definitely need to start a "Source Book" - a lot of possibilities here! I will start checking these.
    Yes, I am a toolmaker [laid off at present, however]. The small bench mill is suitable for only very small work, and is not fully tooled up yet.
    I appreciate the willingness to help a newcomer! Thankyou all! I am looking forward to getting into this bike - I enjoy wrenching almost as much as riding.
    Now that the carbs are clean, I will plumb in a couple of small in-line filters soon.
    sumran
    ...I enjoy wrenching almost as much as riding.
    You'll fit in well as an airhead!
    May 2007
    For whatever its worth, I'd pull the petcocks off first, replace the long screens and the tiny interior ones. Each petcok should have two. They are much finer mesh than external filters. I've removed my external filters after talking with Tom Cutter (rubber chicken racing garage in NJ) because they only effectively slow down fuel delivery. In the end, its just gravity fed and I'm not racing, so it could probably go either way. I just got tired of replacing them since they were a rougher grain filter than the fuel that had already been filtered.
    DS74BMW
    Quote Originally Posted by AnnapolisAirhead View Post
    Good point. Thanks
    Registered User Geoff's Avatar
    Jun 2008
    Southern Minnesota
    Interesting,
    You still see a lot of external filters on Airheads. If the fuel is already filtered, then why the external filters? Are some of the earlier petcocks not filtered? I've often wondered if I'm getting the maximum fuel flow, but I know my petcocks need some attention. I use a tank bag too which might affect venting. Maybe I'll just service the petcocks and dump the external filters. BTW DS74, could you come over and clean and organize my shop? Later,
    Geoff
    1984R100RT
    Living on the trailing edge of technology...
    sumran
    I like the external filters because I can see if fuel flowing. Even if I only have one petcock on, I get plenty of fuel. So the external filters are not restricting fuel flow. On the other hand, I have fairly low expectations for their filtering capability.
    It is a bad idea, but many airheads have had their filters removed.
