Results 1 to 15 of 15
Thread: ST Handlebars
    Herding Cats
    Feb 2006
    Detroit-ish
    ST Handlebars
    So, I finally bought a 2005 ST last week after thinking about it for a few years. And waiting for the prices to come down to meet my meager budget.
    I had ridden one a few years ago and remember the riding position was a bit more extreme than my 1150RS. In researching these bikes on various forums, it seems that there are a couple of options - one that relocates the clip-ons above the top clamp, and another that lets you attach handlebars to the top clamp.
    Well, the bike I bought has handlebars on it. The riding position is very much upright as the handlebars have about a 3.75 inch rise - certainly not ape hangers, but maybe a bit more than required.
    For those of you that have gone this route, what type/dimension of handlebars are you using?
    Aug 2008
    Kingston, NH
    We did both tio my wife's bike to get her sitting position better.
    Route 1 - Verholen Clip On - up and back some but not enough
    Route 2 - AC Schnitzer Handlebar - 28mm bar, also added a 25mm up and back riser -perfect, for her.
    As noted we had both and the preference (night and day) is the AC Schnitzer.
    Hope this helps
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Herding Cats
    Feb 2006
    Detroit-ish
    Semper Fi,
    Do you have approximate dimensions of the handlebars (width and rise, primarily)?
    Aug 2008
    Kingston, NH
    When i get home tonight I'll do some measurements and post some pictures of what was done.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    RTST
    Semper Fi
    I would be very interested to see pictures and know what it takes to install the AC-Schnitzer conversion. My wife rides a ST and it sounds like we are going the same route you and your wife have gone. We installed the Verholen riser setup and as you say, a little better. Would be interested where you got the set backs for the AC-S setup and any oyher parts for the conversion.
    Larry
    Jul 2007
    Big Sky country (Montana)
    Afterwards you'll realize it ain't the bars that hurt; half as much as that seat.
    RTST
    Seat problims no more..Corbin takes care of that!
    Larry
    Aug 2008
    Kingston, NH
    Quote Originally Posted by RTST View Post
    Semper Fi
    Larry
    RTST - the job is fairly straight forward - remove plastic, remove tank, remove clip ons, remove handle bar, remove upper mount.
    From there you swap out the orginal ball joint onto the new mount, replace the original throttle cable with the longer provided one, mount the handle bar mounts, handle bar, grips and mirrors.
    Total time to do the job was a full day - took my time and followed the instructions.
    Quote Originally Posted by BuffaloBob View Post
    Semper Fi,
    Buffalo/RTST - here you go - due to the non-flat geometry of the ST i tried to pick some reference points you can use from a non altered bike:
    Width of bar - start of clutch hand grip to end of throttle handgrip
    Distance from Handle bar edge closest to the driver to tank fill area
    Throttle Side view - the most bottom support is a 14mm riser i had machined (can provide shop used details if needed), the second is the riser from AC SChnitzer, the last is the up and back riser from SW Moto.
    Clutch side view
    Top View
    Zoomed Top View
    Here is the link to who carries it - note it is a 6 week lead time
    http://www.ascycles.com/detail.aspx?ID=44375
    Total Change from stock is as follows:
    - for the AC it is up 70 and back 100 (IIRC)
    - 14mm shim
    - 25 x 25mm up and back riser.
    I was able to do the whole job myself except for the transition of the ball joint from the old clamp to the new one. This requires a 43mm socket and a special holding fixture - that portion of the job was done by my BMW Dealer - Max BMW
    I have the instructions at home - but it is a 4 meg file so if you are interested pm with your email address and i will send it to you.
    Cheers!
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Herding Cats
    Feb 2006
    Detroit-ish
    Semper Fi,
    Thanks for the pictures and the measurements. After looking at my bike, I've concluded that it does NOT have the AC-Schnitzer conversion, but some other handlebar conversion kit. I can't even figure out how the handlebars come off!
    I'm estimating that with the higher rise handlebars I have, the final position is probably close to that on your wife's bike. Guess I'll quit thinking about this for a while and just ride!
    That is a very slick set-up you have, though.
    May 2007
    Western NY
    Wunderlich sells a similar conversion. Could that be what you have?
    RTST
    ST Handlebars
    Semper Fi
    I too thank you for your information and photos, nice of you to do so. I will show them to the wife and see if she wants to procede (I'm sure she will). Since you say it is a 6 week timeframe we better get going on it. I actually saw these on the A&S website (I bought my RT from them) and finding out someone had them installed is a great help...thanks again.
    Larry
    Aug 2008
    Kingston, NH
    Semper Fi
    Larry
    No problem - glad to help.
    Give them a call - the lead time may be less now.
    Any more questions let me know.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Aug 2008
    Kingston, NH
    Semper Fi,
    thanks - appreciate the kind words.
    the handle bars should come off where they are clamped or secured.
    This set up made the difference for my wife to keep the bike.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    The Verhollen set up works the best for me. Don't mind the loose wires, i was wiring up some connectors when i took the pic. You can move the bars above the triple tree without the verhollen kit just to see what i will feel like. If you like the feel then buy the kit and an RT front brake line and you're good to go.
    Oct 2003
    I also have the Verholen kit on my '07 ST, and find it just perfect. (I've also got an R1100RS that I think is just right, too.)
    However, if you have the '07 model (sans whizzy brakes), BMW changed the casting for the brake master cylinder, and it projects slightly more than it used to. In combination with the Verholen kit, it just slightly interferes with the dash. I carefully ground off just enough of the casting to remove the interference, with no problem. I also sent a message to Verholen, and they acknowledged it, so they should be aware (but considering the ST's sales success, I doubt if they'll change anything).
    BTW, my Verholen kit came with the necessary longer brake line.
    http://darryl.crafty-fox.com
