Results 1 to 7 of 7
Thread: 1977 R100 oil leak
    Registered User TIMRFO's Avatar
    Jul 2004
    southwestern Mi
    1977 R100 oil leak
    I have a 1977 R100 and on the left cylinder its starting to seep a little oil between the block and cylinder , it that normal? it doesn't leave drips on the gound. Tim
    Bill Burke
    Normal. The block/jug joint can be resealed, and should be done at the same time that you install new pushrod seals. So wait until your pushrod seals start leaking. I've had very good results with Yamabond grey sealant.
    Arkansas
    Wander over to airheads.org and read the various tech articles. There is danger in too much sealant. I was amazed at how little it took.
    mymindsok
    Yep!
    You can clean the bases and base shims, add a little smear of sealent and it should stop the seeping.
    It also helps tp keep your studs torqued to spec. The jugs usually begin leaking after the bolts on the studs get a little loose. Once they begin leaking, sometimes torquing them stops the seepage, sometimes not.
    Wisconsin and Florida
    .............."It also helps tp keep your studs torqued to spec. ".................
    Resist the temptation to stop this minor leaking by torquing or overtorquing
    the long studs that pass through the cyl and heads. It is quite easy to
    strip these studs out of the block and if you do not know what the PO may
    have done before you never mess with them for something as trivial as
    minor seeping. spray can engine cleaner from WMT about $1.50 will keep
    this area clean for a year/can.
    Quote Originally Posted by 44006 View Post
    never mess with ... something as trivial as
    minor seeping.
    That's my philosophy for the whole bike. Haha.
    Arkansas
    Quote Originally Posted by crazydrummerdude View Post
    The Airheads List had a bit on this. They recommended Gunk and water, twice a year....
