1024JLC
I have an 04 R1150RT which has the "free-wheel" pully on the alternator, and apparently there is a "special tool" required to spread the upper and lower pullies apart in order to acheive the proper tension on the belt. The old method of using the torque wrench at 8 nm apparently will not work, at least from what I have read thus far. I have two questions:
1) Is there a way to spread the distance between the two pullies without the special tool?
2) Does anyone know what the distance in mm is supposed to be between the two pullies, when properly set?
I find lots of information regarding the older "poly belt" adjustment methods, but nothing about the "Elast Belt", except going to the dealer due to special method and special tool requirements.
Kind of makes me wonder what one would do if the belt need changing in a remote area on an extended trip.
Thanks in advance for your input.
