Sailingfool
The difference? $19,993.
Here's your sign..........
It is amazing people will drop $18K+ on a bike...
It is amazing people will drop $18K+ on a bike and bitch about a $17 oil filter, that most only change once a year... I personal use Toyota oil filters in our bikes, since we drive Toyota vehicles and use the same filters. I do buy a BMW filter once a year to get the crush washer and oring, but use the Toyota filters in between. I don't buy new bikes, so I support the dealer buy buying all my parts through them.
My cure now is to use K&N #163 filter. They have a 17mm nut welded to the bottom. $13.99ea. online.
Ragman
The Lisle coil wrench is discontinued.
Ragman
I think the number of flutes is different. I'd go to an auto parts store or big box store and buy the size wrench designed to fit that filter. Get a metal one - the plastic ones won't fit up into the sump. And, you may need to grind a few ridges off the outside diameter of the wrench.
As an alternative - drill a couple of holes in your BMW wrench and drive sheet metal screws up through the filter into the filter can. Messy - but it works. Drill the holes closer to the outside circumference than the center for good leverage.
Glad you could get it off, but i'm curious about how "that thing was on too tight" = "what a poor design".
i've probably done 25+ classic k oil changes in my life and never had a problem with the filter being too tight. Two quick points....
Filter cup removers vary widely in fit. My good friend recently bought a k75c and i gave her a bmw oil filter kit i had laying around. We took the filter to autozone to find the correct filter cup, and even in the same stack of the same cups the fit varied widely. Very snug is perfect so it will hold the filter tightly when slid on - loose is bad. It is actually a nice filter cup (especially for $6), the fit is better and the sides are deeper, providing a better and more stable grip, than the $20 one i bought at my local bmw dealer many years ago.
When putting the new one on your classic k, put the filter in the filter cup, oil the rubber gasket (fill filter with oil at your discretion, i always do), screw in hand tight to snug, insert ratchet and turn 1/4 revolution. That is it, you'll want to tighten more, don't do it!
