mistercindy
About ten years ago I bought a $80 Husky air compressor from Home Depot. Cheap, but functional enough for car tires, motorcycle tires, balls, swimming pool inflatible things, etc... Everything but bicycle tires since it won't adequately inflate over 80 psi or so. Its been okay, but only just.
My biggest problem with it is the hose. It came with a 25' hose that is coiled up. Its made of a plastic that isn't very pliable, so the furthest that 25' hose will reach is maybe 6'. Even then its a PITA to use because the hose is so stiff. That, and the darn thing crimps, and it finally developed a crack. I went to the Home Depot web site and find the $4 deal kit to fix the hose. But even then I'm still stuck with a crappy hose that now has a weak spot in the middle.
I'd like to just fix the hose, but there's a big part of me that wants to bite the bullet and just get a decent air compressor that's more functional.
Questions:
Questions:
- Does anybody know of an all purpose hose of a better quality that can be afixed to any compressor?
- What kind of air compressors do you own and that you'd recommend? I'm particularly interested in those that will inflate enough for thinner bicycle tires that inflate to 100 psi or more.
