KHEEREMA129911
I decided to swap out the Dyna Ignition booster and mechanical points for the Dyna III. The bike was running fine with the ignition booster. However, I cannot get the bike to start with the DYna III.
I've verified the coil resistance at 3.0 ohm. I've pulled the plugs and visually verified I'm getting spark when trying to start the bike. I also shorted the white trigger wire and verified i'm getting spark when shorting the wire, so I'm assuming the module is OK. The ground is secure. Since i'm getting spark when trying to start the bike i'm assuming the pickups are OK.
The plugs are getting fouled so i believe i'm getting fuel. I tried adjusting the timing, but it still won't start. i've tried letting the bike sit with the plugs out to dry it out a bit, but it still won't start with or without the choke.
The fuses in the headlight are ok. battery is ok. the coil switched power lead is showing ~12V with the ignition ON.
I can't think of anything else to check, any suggestions?
