Results 1 to 6 of 6
Thread: Another brake question.
    blah blah blah squiffynimrod's Avatar
    Dec 2008
    Regina SK Canada
    Evening all,
    finally getting around to putting the new seals in the brake calipers.
    The left caliper had a smidgen of a silicone like material at the top where the retaining pins go. The right caliper has way more of it, very rubbery and well adhered, reminds me of an RTV sealant. Original? Purpose? Required on reassembly? I can't find any mention of a requirement in my Haynes or Snowbum's site.
    Thanks, Steve
    No pithy comments available at this time.
    Please check back later.
    James.A
    Generally speaking, a brake caliper does not need a sealant like RTV or silicone.
    I once had a late 70's Toyota Corolla where the calipers were un-able to be rebuilt. Even with new pistons the second time around they would ooze brake fluid when pressurized. In a situation like that, it is not much of a stretch to imagine a novice mechanic trying extra sealant to save a failed rebuild of a caliper that was beyond saving.
    I would still have a go at a rebuild on your caliper if only because replacements are pricey. No need for extra sealant.
    Registered User skiteach's Avatar
    Woodbury Ct
    My guess is the silicon sealant was used to help retain the brake pad retaining pins. Or the PO may have thought a clicking noise could be eliminated.
    '73 R75/5
    Never had a bad day skiing!
    Dec 2008
    Regina SK Canada
    Back to the brakes..... back brakes specifically.
    I've just finished cleaning the rear brake area and installed the new shoes.
    The kit came with a rubber damper for the rear spring. No instructions in the kit, and the one shown in the Haynes manual looks nothing like this one.
    Do I have it in correctly?
    Thanks, Steve
    You have the rubber damper installed correctly, but I would remove it. It makes the spring rub the wheel hub and often rotates, sometimes getting damaged in the process.
    The damper was supposed to reduce squeaking, but I never found that it helped.
    Dec 2008
    Regina SK Canada
    Quote Originally Posted by lostboy View Post
    Thanks. I'll think I'll remove it before I button it up. The old shoes were so worn the rear brakes were almost inoperable, but it didn't have the damper. But no squeaking. I can always put it in later. As a further note, the rear spring was quite loose compared to the front and the new ones. Stretched due to years of use. I'm glad I made this repair.
