Results 1 to 2 of 2
Thread: Ignition switch replacement
    Question Ignition switch replacement
    I'm changing the ignition switch (electrical portion) and wiring harness on my 04 RT. My question is what tool to use to remove the set screw that holds in the electrical portion of the switch? I was told it is a hex, but the mechanic was not sure of the size. 2.5mm seems too large but 2mm too small. Thanks for the help.
    Turns out there is a slot the top of the set screw. A small slot screwdriver is what it took. Credit goes to KER on the RT site.
