Results 1 to 6 of 6
Thread: 85 k100rs low voltage/charged battery
    Hey all. Been reading about all of the starter issues and wanted more info on ground running thru the starter. I have 11.25 volts on the battery and once in, will not even turn the headlight on. Acts like a drained battery. I read in a post that the ground is thru the starter and I need to pull it and clean it but should I be replacing anything (worn brushes?) before putting it all back in?
    Also because of this will I need to tap the relay?
    And will I do damage trying to jump from a car?
    thx
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    11.25 volts is a bad battery.
    How many volts does it drop down to when you try to turn on the lights??
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    [QUOTE=98lee;423637]11.25 volts is a bad battery.
    It read 9.8. Is it a bad battery? Or a combination of crud in the starter/ cold /???
    Neilkamman
    9.8 V is definitely a bad battery. Start by changing that out and see if problems go away. I have an 87 K75S and a new YUASA batt cured my cold-weather ills.
    Normal (I believe) is 12.8 cold, and 13.2 running on a functional alternator.
    There are good threads about this on K-Bikes.com.
    I have a 2yr old 12v BMW gel battery that has not had any problems till now. Have a battery tender and charge it monthly. Shouldn't it last longer?
    Registered User breyfogle's Avatar
    Aug 2004
    Lomita (aka L.A.), SoCal
    Quote Originally Posted by 117336 View Post
    BMW branded gel battaries do not have a strong reputation. A 2 year life is not unheard of. They also require a charger specifically designed for gel batteries. If you want reliability, get a new flooded lead acid battery (BMW/Mareg or other maker). If you want convenience, get any of several brands of AGM sealed batteries.
    '89 K75S Original Owner
    '94 (Beta) R11RS, ( RIP 12-5-2010 courtesy of blind left turning cage driver ) ....
