mbellantone
AirandOil In NJ
Hey guys, thanks for all the great advice on replacing the steering head bearings, but since there's still snow on the ground I figured I'd take care of some cosmetic things which leads me to a few questions about my fairing.
I am replacing the large rubber strip "gasket" around the front, outside were the fairing meets the windscreen, P.N. 46631240649, see fische link below.
http://www.maxbmwmotorcycles.com/fiche/MainDiagrams.asp?VIN=6173761
I've read through what I could on the list about installing it, but are there any hints or tricks on it's installation? It seems that I have copper grommets on the black plastic dash that the inner insert of the "gasket" strip gets inserted into, which don't seem removable and removing the old gasket requires tearing it out. I don't think I can successfully tear the new one in
My second question is, the black finish on the interior of this VERY large fairing has worn out spots, dings and scuffs that have revealed the white below. Is there any way to touch this up without removing the whole fairing and repainting without making it look like I took a roller and a can of Benjamin Moore to it? I DO NOT want to remove the fairing.
Any and all advice is appreciated!
Mike
Mike
