Results 1 to 9 of 9
Thread: 1100R head gasket
    Sep 2006
    CENTEX USA
    1100R head gasket
    Not ready to go to ADVrider....so....
    replacing leaking gaskets on the '95 1100R, pulled head and cylinder to replace the "not there" o-rings on the locating dowels behind the cylinder...maybe a shred of one left.... it was leaking a little here,the majority was the larger gasket around one of the studs.
    anyways, have the old head gasket which is one piece...the new one is 4 pieces riveted together even though the package says 2 ea, the other sticker says 1 piece...I am assuming it is one "four piece" gasket ... the part # is 11 12 1 342 869 And splitting the gasket into two sets appears to be not intended.
    Any confiramtion?
    the dealer called me today and said they had my gasket set in, I am thinking it's the one for the other side.
    also hoping the dreaded stud stripout using the degree wheel is not in my future...read a few diff opinions on re-torqueing those and wouldn't mind a few more opinions
    Sep 2006
    CENTEX USA
    bump...
    nobody has changed one?
    Jul 2004
    Charlottesville, VA
    Changing head gaskets isn't a trivial task; it gets screwed up more than any other repair I can think of. It might be that other members here don't want to get involved if you're not even sure of the parts and you aren't comfortable with the angle-torque procedure.
    The 869 4-layer gasket is the right one (one) and the angle torque procedure in the manual is the correct one also. Make sure you have the cam sprocket correctly positioned on the camshaft before you tighten that down.
    Anton Largiader 72724
    Tech articles - YouTube
    dtpetty
    bump...
    Just finished the job on an 1150RT. It wasn't really that bad. The torquing procedure wasn't NEARLY as scary as I thought it would be. Remember that the prelim torque is quite low. I did the 90 - 90 by starting with the torque wrench perpendicular to the floor, and then bringing it parallel to the floor (90 deg).
    I also had to repair a previously stripped out helicoil on one of the studs. But that's another story...
    Sep 2006
    CENTEX USA
    Thanks Anton & dt,
    I am OK with procedure with angle torqueing, done it a few times...just not on a BMW oilhead head gasket job having heard/read all the debates.
    I played with the cam sprocket line up a few times to see what the issues could be...I'm good on that one too. The gasket set just had me scratching my head with the two diff labels.The new parts guy didn't have a clue ,so I just wanted a confirmation it was the right one
    Thanks again
    Jul 2004
    Charlottesville, VA
    .. having heard/read all the debates.
    Debates? I haven't heard of any.
    Sep 2006
    CENTEX USA
    Without searching where, recently read a few threads on different sites debating whether the torque values in Clymer vs Hanes vs BMW maintenance manuals were correct. Someone stripped threads out on the head studs using one vs the other, another said he did not use a degree wheel method. I typically follow the manuals unless I can have someone justify why not too. As far as trusting everything someone says on the Internet...gotta take that with a grain of salt or I should have a dozen final drive failures by now. You and Paul G have obviously seen your share of issues so I listen better when y'all speak.
    I have all three resources ,but am using the info from the BMW manual I have and have not had any issues personally. Have not compared all three manuals side by side either to see if any differences are noted.
    Just did a clutch job on a local guys '97 R1100, the previous dealership mechanic(s) really did some sloppy work,IMO, and hardly anything was torqued or put back with any feel for craftsmanship , several mounting bolts were really loose before I even touched them...already had a new transmission at 20K according to current owner,yet at 35K it needed some attention. This has nothing to do with the '95 of Helen's I am working on currently,just that I do try to do the thing right the first time.
    Registered User cb75076's Avatar
    Jun 2006
    NJ - outside of NYC
    With guidance from folks on this board, I successfully changed my head gaskets in late 2008. I believe the replacement gasket had 4 layers riveted together. You can follow this thread for the details:
    http://forums.bmwmoa.org/showthread.php?t=30708
    Jerry Holtz
    Maplewood NJ
    Sep 2006
    CENTEX USA
    Got mine back together and purring without a dribble again... all's well!
