pawork
Put new stainless brake lines on the front of my bike last weekend (Spiegler; 2002 R1150R w/ABS).
Main wheel circuit line (i.e. the long one that feeds a junction block to feed both front calipers) was an inch or so shorter than the OEM hose. I put everything back together, bled the system, everything works - I'm just a bit worried about the hose getting tugged out of the fitting over time, since line is shorter. Anyone else encounter this? Photo shows bike on centerstand. Forks can still go lock-to-lock, but hose is pretty taut. When front wheel is on ground, forks compress a bit. So photo is worst-case scenario.
Can't say that I can tell much difference in braking (I did 100+ miles today), but I'm glad I did the project, based on the way the old hose looked.
Paul
Paul
