C
CMCRAE132066
my bike is in storage right now so can't really have a great look at how I might raise the bar height 2 or 3 inches. Any suggestions?
thanks
thanks
Not useless; just not easily adjustable. Set it for whatever you want and remove the knob.A relatively easy way to just raise the bars is to find a set of lower handlebar clamps and add them to the existing ones. This does require you to find and install longer studs, but it works quite well. It will render your steering damper useless, though, just like all bar-back arrangements.
Not unless someone has converted it. The '77 MC was under the tank. Nonetheless, getting all the cables to fit without kinking around something like the instrument pod will be a minor PITA.If your bike has a handlebar master cylinder, you'll need a longer brake hose.
... I loved the bar postion. Sporty and good wind buffeting position for me. Plus the bike looked odd without the dash pad. I enjoyed the clean unclutterd view it provided.
Wow, I found out that this wonderful design is the best in the world for blocking the wind even when you would really like a little wind! But then, that is not much of a problem, I live in Wisconsin.... I got tired of melting behind the RS fairing in the summer ...
...and the poor cornering characteristics ...
was something broken? I have never been on a better handling motorcycle...
After I completed the re-do of the bike I found that I preferred the handlebars in the stock position. I've also found that a slight adjustment (rotational) to the bars can make a lot of difference in the comfort level in riding.
...I noticed that you have what appear to be two fuse holders on your dash panel, one on either side.
Is that, in fact, what I am seeing there? Did you (or the PO) get your fill of dealing with a blown fuse down inside the headlight bucket (at night?)
The bike came with in-dash fuse holders. I didn't care for them, but I did want more accessable fuses of the blade-type. I obtained some water-proof blade-type fuse holders and located them beneath the dash. The old fuse holes were plugged. I also replaced the original clock and voltmeter with some VDO units from a marine supply outfit.
.....None of this is "Stock" of course, but personally, I don't care! I like mine better than a stock one.
Had this 77 RS for almost 8 years.
I got tired of melting behind the RS fairing in the summer and the poor cornering characteristics and sold this... upgraded to a 95 R100R. Best move I have made in a long time.
I need a new clock and voltmeter for my '78 RS,what marine outfit did you get yours from? they must have cost a lot les than stock replacements from BMW. Ilike the look of them.
