K
keelerb
1984 R100RT.
Cannot get any pressure in the rear brake system. New master cylinder, new line, no apparent leaks, I can bleed for hours (I have done so), there doesn't even seem to be any air coming out the bleed line, but I can't get ANY pressure up (enough to push fluid out the bleed line, yes, but that's it) - not even enough that I can't turn the rear wheel by hand with lever fully depressed.
I have reverse bled, vacuum-bled, "normally" bled, and speed-bleeder bled. I've pumped two full cans of brake fluid through the system.
I've always hated bleeding brakes but this is ridiculous.
Anybody ever run into this?
Thanks.
Thanks.
