Results 1 to 3 of 3
Thread: rear wheel play k12rs
    eric2
    Question rear wheel play k12rs
    I've a 98 with 74K on it. I can feel a fair amount of lateral play
    by placing my hands at 6 and 12 o'clock positions on the rear wheel, mebbe a tenth of an inch.
    I don't feel that much at the 3 and 9 positions, and the newer models I checked at the dealer had predicatbly little or no play.
    I don't hear any noise and there are no leaks, should I be concerned? is there and adjustment on the paralever rear
    hub?
    TIA!
    Eric barnes
    Austin, tx
    Blocking the slow lane
    Edwardsville, IL
    Two possible spots:
    1) The Paralever pivot - if this is loose, you should notice it regardless of where you place your hands. These come loose periodically tho, so that's the first place to check.
    2) The final drive - if this is loose, you probably need to have the final drive disassembled and the bearing assy reshimmed.
    That said, the first final drive on my K75 had situation 2) for thousands of miles. Never got worse.
    Jon
    Jon Diaz
    BMW K75
    MOA Ambassador Emeritus
    Focused kbasa's Avatar
    Re: rear wheel play k12rs
    hub?
    TIA!
    Eric barnes
    Austin, tx
    Marin BMW told me that they expect to deal with that by retorquing the lower paralever at about 40K miles. I torques mine as it had started to develop a little play at 30K. I think the inside (wheel side) 12mm Allen fitting gets torqued to 7 ft. lbs, but I'd have to go look to make sure.
    Dave Swider
    Marin County, CA
