Results 1 to 15 of 20
Thread: Centerstand
    Centerstand
    An earlier post talked about getting a bike off the centerstand. My problem is getting the bike on the centerstand. I weigh 140 lbs (I lift weights and am in good condition) but I can't get the bike on the centerstand no matter how hard I pull, tug, lift..... I folllow instructions by standing next to bike, place my left hand on the left grip ( straighten out bike), push down on the centerstand with my right foot,
    with my right hand I grip part of the frame , and pull back..like crazy. Nothing happens. Help.
    Sep 2006
    CENTEX USA
    what model bike?
    Man, I wish I weighed 140 lbs again.
    I can't believe it takes 50 lbs of belly fat to lift a BMW onto its center stand. Maybe it's a balance thing.
    Braz J Brase's Avatar
    Jan 2005
    Central Indiana
    Quote Originally Posted by dachstom View Post
    Try pulling UP and back - mostly up - and see if that helps.
    John
    ... I place my left hand on the left grip ( straighten out bike), push down on the centerstand with my right foot,
    Try facing the bike hands placed as you noted. Then use your left foot and shift your weight to the right while pulling back. Don't try to lift the bike. Try to "pull" it onto the stand.
    Keep the side stand down until you get the hang of it. Just remember, don't try to lift. You'll hurt just "yo'sef"!
    ~ Jim
    Registered User thompsonr's Avatar
    Nov 2007
    Topeka Kansas
    Center
    Make sure you have the bike strait up. I push the center stand down with my right foot on the foot bar of the center stand till it touches the ground ( left leg of the stand) then push the bike away from me till the right leg of stand touched the ground. Step down on stand lift up and back on bike.
    R and R
    Goibnui
    Centerstand
    Another point to remember if you have a bike with saddle bags and travel trunk, either have the bike in neutral or pull in the clutch. with weight on the rear, the rear wheel does not come up easily and puts enough drag that I have trouble at 225# with the bike in gear! With the clutch pulled in, it is a piece of cake.
    Steve
    taller than wide GRANTMACEACHERN's Avatar
    Ontario
    Quote Originally Posted by Goibnui View Post
    Steve
    that's what i was thinking. despite never having an issue with putting my GS on the stand, a few times i was trying to pop it up onto the stand wondering why it wouldn't go. a quick check to notice it was still in gear made me feel pretty dumb. oh well.
    interestingly, my old airhead RS was much more of an effort to get it on the centre stand than my big GS. Even fully loaded the GS almost gets onto the stand itself. I barely have to lift it.
    g r a n t
    Registered User stkmkt1's Avatar
    Sep 2008
    Tremont, IL
    centerstand
    You are not using the correct technique. The secret to putting a bike on the center stand is to use your foot to push down on the centerstand lever while gently pulling up and back on the bike. I ride a bike from the 70's that weighs in at about 550 lbs. Many people are amazed at how easy I put it on the center stand. But if you let your foot do most of th work, you will find it much easier. I'm buying a new GSA and recently tried its centerstand. Compared to what I face with my antique Honda, the BMW feels like it weighs about 100 lbs. I could not believe how easy it goes up. It is almost as if it goes up by itself. Once you get the technique down, you will laugh at others who struggle to get their bikes on center stands. Oh, by the weigh, I'm a little guy, 5'6.
    BUDDINGGEEZER
    Quote Originally Posted by stkmkt1 View Post
    +1. The harder you step on the center stand, the easier she goes up.
    Ralph Sims
    On the Road
    Mar 2007
    Greenville&Edisto Island SC
    I had a heck of a time learning to get my Roadster up on the center stand. Here is the drill:
    1 Stand at the left side of the bike while it is on the SIDE stand.
    2 Push the center stand down with your RIGHT foot until it contacts the ground.
    3 With your left hand, and still holding the center stand down, push the bike, over, away from you, carefully, until BOTH legs of the center stand contact the ground.
    4 Now, with your right hand, pull rearward on the bike's frame while pushing downard on the centerstand.
    5 Notice, I did not sat to pull back on the handlebar; this is not needed. when you do the procedure correctly.
    The motorcycle will easily rotate up on to the centerstand.
    The trick is to get BOTH legs of the centerstand to contact the ground. The first time you do it, it may feel as though you are going to push the bike over and lose it.
    BUBBAZANETTI
    focus on the FOOT
    not the arms
    i can put most bikes on their centerstand using my hands just for balance, push down hard with your foot, you're using it as a lever. when you get good, you can do it barefoot.
    don't ask me how i know.
    How cold was it? shoeman's Avatar
    Jun 2004
    Lake Wabaunsee, Kansas
    Where do you grease the centerstand?
    Jim Johnson, OP Kansas
    Marcus Aurelius: "The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane."
    No sweat. I finally got the technique down. The bike goes up like a charm. Thanks for all the assistance. ( Now I don't feel like a whimp).
    DZIMBRIC
    Steve
    You actually do that with the bike in gear???
