Originally Posted by
kenk
If you change your own tires with steel tire irons, you probably have purchased the rim savers to keep from marring your rims or just not worried about the marring. I've tried the Rim Savers commonly sold by several sources and leather strips with no success.
A good friend recommended simply cutting a water or coke bottle into strips and using these for rim savers. I changed a tire today using this method and was surprised on how well it worked. The plastic worked as a great buffer between the rim and tire Iron, resulting in no damage an actually made it easier to get the tire to slip on the rim, since the plastic is slick. These plastic strips take absolutely no room to store if on the road and cost nothing to make. After 34 years of riding and maintaining a motorcycle, I thought I knew most of the tricks. I just learned a new one that I will always use when changing a tire with irons.
Hey Paul...your may want to consider for Touring Tips.
