Results 1 to 14 of 14
Thread: Help! How can I get my hazard lights off?
    I have never used the hazard lights on my RT. Tonight I tried them but now can't get them off. Any tips? The owner's manual didn't help.
    Future BMW WSB Racer YELLOW_S's Avatar
    Sep 2006
    Shawnee, KS
    The little red button with a triangle in it. On the left handle bar (I think it's left.)
    I've pushed little button that so many times it's about to fall off. Is there a fuse just for the flasher that I can pull?
    Lifetime Member Ridealot's Avatar
    Aug 2004
    Salem Or.
    I think on my bike I have to turn the key back on and then turn off the flashers.
    But neither of my Beemers are Oilheads so it could be completely different on your bike.
    Tom
    Salem Or.
    '93 K1100LT w/Bushtec
    '09 F650GS '15 Ducati Multistrada
    Registered User heavyjetpfe's Avatar
    Mar 2007
    Snellville, GA
    On my 06 RT I turn on the flashers by thumbing both turn signal switchs at the same time. I cancel them by hitting either turn signal then hit the cancel switch
    South Carolina
    like RIDEALOT said, turn key on then off...
    Tried all of the above and nothing works. How do I disconnect the flash unit?
    Hey Rotten:
    I have a 1996 R1100RS, I believe all oilheads up to 2004 are very similar but...
    If yours is the same as mine, the flasher unit is inside the fuse box, center row, far right(biggest module in the box).
    If you remove it, you will have no turn signals(perhaps a lesser evil than full time hazards).
    The unit accepts 4 inputs:
    Left turn.
    Right turn.
    Turn signal cancel.
    Hazard.
    I'm not sure what would cause it to behave this way but I would clean the flasher unit connector contacts, and the hazard switch contacts, before replacing the flasher unit.
    Mike Marr
    Well it looks like the Kisan Signal Minder was the culprit. The previous owner had installed it and fortunately included the original flasher in the "goodie box".
    Things work fine now - thanks for all of your responses and help.
    On the Road
    Feb 2008
    Rhode Island
    Ancient Chineese Secret: He who adds extra crap to his scooter has
    Has extra problems
    Aug 2004
    Salem Or.
    Tom
    Salem Or.
    South Carolina
    Quote Originally Posted by My04Boxer View Post
    Has extra problems
    +1 Like the guy that complained about his headlight not working at the Gillette Rally this year. rode all the way home with flashlights. then discovered his headlight modulater had quit.
    Sep 2006
    Shawnee, KS
    Me thinks we has a troll!
    Oct 2005
    Whitefish Bay, WI, 3mi N Milwaukee
    push the hazard cancel switch.
    "What is beautiful is simple, and what is simple always works"....Kalashnikov, inventor of the AK-47.
    Current bike: 2015 Yamaha TW 200, modified for road/street use with tire, sprocket upgrades. "Center yourself in the vertizontal. Ride a motorcycle...namaste' "
