Results 1 to 12 of 12
Thread: Help! Plastic on pipes!
    I ride a 1999 R1200 C and my question is:
    I need advise on how to get melted plastic (WalMart bag) off of my pipes without damaging or scratching the pipes.
    93 K1100RS & 81 R100RS
    Nov 2006
    Hales Corners, WI
    Plastic on pipes
    I had a sopt on my chrome exhaust canister on a 93 K1100RS,
    Used " Never Dull " to get it off.
    Comes in a can, gotta rub a bit, but it worked.
    U can get that at Wally World too.
    ARValkguy
    Never dull is great stuff. It looks kind of like a gross cotton ball. I used hydrogen peroxide first then never dull to get some shoe rubber off.
    Jun 2007
    I use Bar Keepers Friend. Had a plastic zipper/pant leg melt onto my wife's R12C and we happened to have that around to make the stainless steel sink pretty, and I thought....and sure enough the mild abrasive was enough to remove the plastic as well as other road stuff and bug stuff. Buffed up really nice, no scratching or polish marks. Use it on my K exhaust all the time, too.
    Jim Douglas
    Sheboygan, WI
    Thumbs up
    Easy-Off oven cleaner.
    Spray it on when the pipes are COLD. Wait a while, and then clean off.
    Good Luck!
    Kevin Greenwald - MSF Lead RiderCoach # 121656 (BRC,SBRC,IS,IME,SMARTrainer)
    Motorcycle/High Performance/Teen/Winter/ATV Driving Instructor - ROAD AMERICA Track
    Ozonkiller
    I did the same thing with my RS. I rode it for a while before I got around to cleaning it and most of it just cooked to the point that I could clean it off with my finger nails. Then I used Wright's Brass polish. Great stuff. Better than any motorcycle specific stuff and available at about any grocery store.
    gvpurvis
    Oven cleaner work wonders.Spray on when cold let set wash away..
    GVPurvis
    Eastern KY
    RE:plastic on pipes
    I bought a used low pipe for my R1100R a few yrs back that was cheap but covered with melted bike parts-use acetone or hot lacquer thinner combined with the lowest kind of grit you can to remove-that could be the bar keepers friend or 0000 steel wool or comet or a razor blade held at a sharp angle for the worst. Ideal is a solvent that melts the plastic and results in less abrasion and effort.
    '02 1150 RT cardno7's Avatar
    Apr 2007
    Louisville, Kentucky
    Watch the oven cleaner, it will take the finish and/or paint off other surfaces and will strip the finish off engine block. I have an RT but have seen a 1200 C that had the engine block damaged by oven cleaner.
    If you are cleaning chrome, extremely fine steel wool works well. 0000 steel wool.
    Beemerphan Radar41's Avatar
    May 2003
    Longmont, CO
    Smile Cleaning plastic off pipes.
    Quote Originally Posted by cardno7 View Post
    Dito, try 0000 steel wool and car wax worked on my 84 RS pipes. Make sure the pipes are COLD!!
    radar
    Don "Radar" Wreyford
    00 K1200LT, 98 R1100GS AE, 84 R100RS, 76 R75/6
    MOA # 91738, RA #27032 , ABC #7915 - "Insanity is doing the same thing over and over again, but expecting different results" - Albert Einstein
    Aug 2004
    SE Michigan
    You can also try scaping it off using a razor blade. I had good success with that method on my CLC. You hold the blade almost parallel to the surface.
    Dan
    I melted a strap from my backpack on the pipes of my R1100S. I was on the road, so I just went with it. The plastic very quickly oxidized and went away without a stain. Of course I was concerned that it might flash, but it was far enough away from anything else (body panels, etc.) that I could stop and let it burn if needed.
    Yeah, not the smartest method, but you only live once.
    David Andrews
    00 R1100S
    09 K1200R (on order)
