Results 1 to 11 of 11
Thread: Noise on start up?
    canadianbrummie
    Noise on start up?
    Today when I started the bike up there was a wooshing metallic noise, it only lasts a couple of seconds. I don't know how else to describe it. Any idea's?
    cheers
    CB.
    Registered User awagnon's Avatar
    Jun 2004
    Ogden, Utah
    Typically you hear a metallic rattling sound from the left side cam chain tensioner, which lasts a few seconds. I'm not sure about what you are describing. Make the sound for us again....
    Al - Ogden, Utah
    Boxer bikes, boxer dogs, and letterboxing.
    2004 1150RT and 2018 Triumph Tiger 800xrx
    canadianbrummie
    Quote Originally Posted by awagnon View Post
    It's similar to the sound when you try to start your car engine when it is already running, although not as harsh maybe.
    Quote Originally Posted by canadianbrummie View Post
    Could be you need to remove, clean & lube your starter.
    They call me Gort scootrp125x's Avatar
    Sep 2004
    Argyle Texas
    Mine makes the metallic rattling sound you describe. I guess that is normal.
    04 R1150RT
    Old man in the mountains osbornk's Avatar
    Feb 2006
    Marion VA-In the middle of some of the best riding in the country.
    The cam chain rattles until the tensioner gets oil pressure. It's normal.
    'You can say what you want about the South, but I almost never hear of anyone wanting to retire to the North.
    cheesewhiz
    Now THAT is funny.
    Jun 2004
    Ogden, Utah
    Quote Originally Posted by BluegrassPicker View Post
    BluegrassPicker makes a good point. Here is a link to a good PDF on starter lubrication:
    http://www.bmwrt.com/faq/docs/starter.pdf
    Al - Ogden, Utah
    canadianbrummie
    Thanks for the feedback guy's. Appreciated as usual.
    JANMILLER
    had what appears to be the same or similar sound.
    Removed starter, cleaned gunk off the shaft, but didn't disassemble as far as .pdf goes. Sound went away...
    rglassma
    I have what seems to be a similar problem on my 05 R1200RT.. What is the downside to not performing the procedure.. The squeal doesn't really bother me...
