Results 1 to 8 of 8
Thread: strapping down an Airhawk seat cushion
    Jul 2003
    bay area, CA
    I bought an Airhawk seat cushion awhile ago, and have tested it out a bit, but am looking for a away to strap it down onto my GS. I don't want it blowing away if I stand on the pegs for a second. Would just small bungee cords do?
    Any suggestions?
    West Salem, OH
    What about velcro? Three or four 1 or 2" pieces should do the trick. Put the soft side on the seat, so if you ride without it it will be less uncomfortable.
    Gale Smith
    2009 Versys
    1999 R1100RT
    State of Confusion
    How about stapling it to the seat?
    -=Brad
    On the Road HELLIOTT's Avatar
    Oct 2003
    Osceola County, Florida
    I use a couple of small bungee cords, but I've put tie wraps trough the loops on the Airhawk so that I can remove/attach the bungees more easily.
    Hall
    jlsworks
    I use long strips of velcro, available at any fabric store. A strip or two of sticky under the seat and wrap the long strips through the loops and then down under the seat. Voila...
    I purchased one of those wonderful pads last year and tried string, bungee cords and some stretchy stuff my wife had. I ended up using the palstic Quick Clips and 1" wide stretchy material all purchased at one of those fabric stores. Yes I went in myself and no one laughed even when I asked where the sutff was. I then sewed the receiver clips with a 1" wide nylon lead to the cloth tabs of the seat cushion. Threaded the stretchy stuff into the male clips and laid that under the seat. I only did one strap and it has proven to be OK so far after 7k miles.
    later tom
    USERNAME
    i had mine sewn onto the seat of my pants. i never lose it now.
    Jul 2003
    Bluegrass State
    try using a sheepskin over the top of it to hold it down and provide even more comfort. got mine from Barb at Alaska Leather
